Question about Singer Sewing Machines
Why won't my old manual singer sewing machine needle move?
The wheel turns, the gear that turns bobbin winder works but the needle will not move up and down.
  • Singer Master
  • 631 Answers
1. Disengage the bobbin winder.That is done by moving the arm away from the center wheel. 2. Tighten the hand wheel. When you tighten you should have resistance like a jar has. If this doesn't then continue. 3. Loosen the small screw attached to the hand wheel center lug. Now, move the hand wheel into a position where it will tighten. 4. Go ahead and tighten the small screw. Now, it should move.
Posted on Nov 19, 2014
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 980 Answers
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Posted on Nov 22, 2009
marigold1m
  • 3 Answers
SOURCE: singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Posted on Nov 28, 2011
  • 1564 Answers
SOURCE: My Singer Simple 2263 is not sewing. The needle won't move up or down. The machine makes a dull hmmmmm sound. When I try to manually turn the hand wheel, it is very tight and hard to turn. I t
Sounds like the motor might be having problems. I would take it in for a proper servicing.
Posted on Nov 12, 2012
The needle My singer 337 will not move. It is not the bobbin winder. Any idea what it could be?
Sounds like it's stuck somewhere. I know this website has many user manuals for Signer machines, so maybe check there for further help? Download Free Manuals
Jan 04, 2016 | Singer Sewing Machines
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do you
have to disengage the center wheel in the handwheel to wind a bobbin?
or do you have to just move the bobbin winder spindle to the right to
wind the bobbin?
do you have a manual for the machine?
Sep 06, 2012 | Brother VX1435 Mechanical Sewing Machine
Machine will not go forward when pressing the foot pedal. Manual says something about checking bobbin winder indent. What is a "Bobbin winder indent."
bobbin winder is the little spindle on top usually right side above the flywheel. you need to move it left away from the stop as this engages the bobbin winder and disengages the needle movement. your manual should show this under Winding a bobbin. these machines dont have a clutch on the flywheel, just moving the bobbin spindle declutches
Sep 18, 2011 | Singer 6038 Mechanical Sewing Machine
My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
I hope this helps!
Mar 29, 2011 | Singer 1120 Mechanical Sewing Machine
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Sewing Machines Logo
112 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
