Question about Electrolux 24" Stainless Steel Built-In Dishwasher - EI24ID30QS
My new garburater caused my sink to back up in into my new Electrolux dishwasher. The line was snaked and all is fine except the time delay button on my dishwasher keeps blinking and beeping and the p
My new garburater caused my sink to back up in into my new Electrolux dishwasher. The line was snaked and all is fine except the time delay button on my dishwasher keeps blinking and beeping and the pump is on. I have to turn the breaker off to stop it. A technician can't come for a week. Any suggestions??
  • Electrolux Master
  • 10,291 Answers
Take the drain hose off the machine and look at the pump outlet for an obstruction. While the hose is off, be sure the hose is clear of any remaining debris .
Posted on Nov 19, 2014
muttandjeff
  • 359 Answers
SOURCE: Nearly new Electrolux dishwasher - DEAD
2 THINGS COME TO MINE EASY CHECKS , MAKE SURE THE DOOR IS CLOSING PROPERLY AND THE DOOR SWITCH IS MAKING UP WELL AND CHECK TO MAKE SURE THAT YOU HAVE 110VOLTS LEAVING THE BREAKER AND @ THE DISHWASHER CONNECTION IF IT HAS A RECEPTACLE ON THE DISHWASHER END TRY TO PLUG IN ANOTHER DEVICE SUCH AS A DRILL OR SAW OR OTHER APP, TO SEE IF IT WILL RUN THIS IS A BETTER CK THAN A METER BECAUSE IT PROVES IT IS PASSING CURRENT AS WELL AS VOLTAGE , METERS ARE NONE LOAD DEVICES AND CAN FOOL YOU
Posted on Jan 10, 2009
jan mczeal
  • 632 Answers
SOURCE: electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Posted on Aug 31, 2009
SOURCE: I have an electrolux edw5505eps dishwasher. The
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
Posted on Nov 26, 2009
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Posted on Dec 12, 2009
tattootech2
  • 72 Answers
SOURCE: All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
Questions about snaking the drain line for a Bosch SHU5305. Should I be able to snake all the way from the sink connection into the dishwasher or is there some type of backflow prevention or something...
I would NOT recommend you snake into your dishwasher because you could damage the drain pump.
If you think you have blockage, then take the unit out and disconnect the drain line and take it outside and use a hose on it.
Just remember to disconnect the power first.
Jul 16, 2011 | Dishwashers
When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
Dec 07, 2010 | Microwave Ovens
Electrolux error code 1, how to reset.
Also got error code 01. Unplugged dishwasher, turned off water supply, disconnected water supply line at sink so it had slack to pull dishwasher out of built-in space, removed two wood screws holding dishwasher to counter, pulled it out onto floor, put it on blocks as reader suggested, tilted to side 45 degrees, water drained out onto rags. Then restored to upright, restored supply line and opened valve at sink, plugged back in, unit automatically reset, returned to built-in, reinstalled screws to counter. Worked like a charm. Took more time to read everyone's advice than to do the job (about 30 min.). Thanks.
May 20, 2010 | Dishwashers
Water is coming out of air flow gap. I installed a new air-flow gap and all new lines from air flow gap to sink (except the line from dishwasher to air flow gap) and i still have water coming out the air...
The leak in an air gap is usually caused by a clogged sink discharge line. Most of the time this is connected to the garbage disposal and there is food particulate in the drain hole where the dishwasher drain from the air gap to the garbage disposal connects.
Pull the sink connection hose off and clean the hole thoroughly. You can try testing the dishwasher/ air gap by placing the disconnected hose into a bucket during the pump out period. It should not leak. After this test...reconnect the hose to the sink connection.
If it is NOT connected to the garbage disposal then remove the hose and clean out the hole where the connection is made. This is a common problem and easily resolved by the user.
Thanks for using FixYa.
Kelly .
May 18, 2010 | GE Nautilus 24" Built-in Dishwasher
I have an electrolux edw5505eps dishwasher. The control panel start button does not function, the delay button does noy cycle thru the delay time. Does the panel need to be replaced?
Nov 08, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
This is a very good web site. Thx for pulling it
It is possible the check valve is sticking causing sour water to come back into the washer. The check valve is located where the drain line connects to the back of the dishwasher. Also make sure the drain line is higher than where the line connects to the drain under the sink. Most washing machines have a loop built into the line but it helps it to drain better when the line is higher. Try hooking the line to the top of the cabinet under the sink if possible.
Sep 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher is backing up into my sinks and all over my new floors help
The drains can be configured a number of ways. Here's what you need to do:
Look under your sink at where the corrugated dishwasher drain line connects to the drain. From there, trace the main drain line to the wall. Your line will be clogged up in that area. Get something to catch the water, and disassemble the drain line until you locate the pluggage. Reassemble.
Best regards, --W/D--
Aug 08, 2009 | Electrolux Kenmore 24 in. Built-In...
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Electrolux 24" Stainless Steel Built-In Dishwasher - EI24ID30QS Logo
157 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
