Question about 1A Auto Parts 1995-1997 Chevy S10 Blazer Heater Core
Why won' my head lamps come on - 1A Auto Parts 1995-1997 Chevy S10 Blazer Heater Core
    Sergeant:
  • 266 Answers
Check the fuses under the hood and side of the dash, assuming bulbs are ok.
Also could be chaffed wiring, headlight relay or the ground for the relay or bad wire connection at the muli-switch(turned signal switch).
Posted on Nov 19, 2014
Horn doesn't work, revrese lights won't come on, and 2 of the 3 break lights won't come on on 1995 Geo Tracker. Fuses are good and bulbs are good.
for how long, 1 day, 1 year , 1 decade? is it a daily driver
or a barn stored, winter car.?
the real question,is there 12v exiting the fuse, the acid test. that.
any volt meter does that in 5min flat.
3rd brake light is bad bulb or corroded socket.
what tranny< 3,4,5,sp.? but in each case it takes a good rev.
switch, if 12v enters said switch and does not exit, its bad.
0v bad,6v rev. path shorted to ground,12v good.
btw, all clamps can short, try 1 new one. in each path all by lonesome. dig?
bulbs good means what.
1: look good.
2: glow when placed on a 12v battery
3:measure 0 ohms with meter (means good or shorted.
4: or they are new and assumed good, (p/n ? what is the p/n?)
head lamps good.? parking lamps, blinker, are all other lamps working. does car start?
Dec 05, 2012 | 1995 Geo Tracker
Headlights won't turn on
check fuses for head lamp
Oct 03, 2012 | 2006 Subaru Outback
Head won't work on dc 11
1) test the outlet wall with another devide such LAMP, if work is o.k
2) the problem will vacuum power : a) test the switch b) motor itself repair or replace.
God bless you
Sep 27, 2012 | Dyson DC11 All Floors Bagless Canister...
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
Sep 04, 2012 | 2001 Hyundai Sonata
My tv's lamp is brocken where is the lamp locatin
You have this listed under a heading for a conventional CRT (picture tube) set. CRT sets don't have a lamp, but the picture tube does have a filament like a light bulb. The filament can burn out so the tube doesn't work any more. Other problems can cause the screen to be shut off, though. If the trouble you're having is that there is no picture, you won't fix it by replacing a lamp. There isn't much (actually, nothing) most consumers can do to repair a modern TV. It usually needs service by a professional with the tools and experience to diagnose the trouble and repair the set
Sep 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Daytime running lights won't shut off on 2001 grand am
check the drl 9daytime running lights0 relay under the hood. I could be stuck in the on position.
May 29, 2011 | Pontiac Grand Am Cars & Trucks
My passenger side headlight won't open. How do I fix the problem?
Ok you might have to replace the motor that lifts the head lamp assembly
May 25, 2011 | 1997 Pontiac Firebird
How to replace headlights bulbs in a grand cherokee 2001
  1. Remove the jack screw attaching the top of the head lamp to the head lamp mounting module.
  2. Grasp the upper inboard and lower outboard corners of the head lamp and pull the head lamp outward.
  3. Remove the bad bulb socket from the head lamp module and remove bulb from socket.
  4. Install new bulb into socket and reinstall socket into head lamp module.
  5. Position the head lamp on the vehicle and align the ball studs with the sockets.
  6. Push the head lamp inward to secure the ball studs with the sockets.
  7. Install the jack screw attaching the top of head lamp to the head lamp mounting module.
Do not touch glass of halogen bulbs at the oil can cause the headlight to blow out
Nov 12, 2009 | 2001 Jeep Grand Cherokee
How do i replace a sidelight on a grand cherokee '53
The whole head lamp assembly has to come out to replace the headlight bulb. Here's how to do it.
REMOVAL:
  1. Remove all of the bulb sockets from the head lamp module.
  2. Separate the head lamp from the vehicle
  3. INSTALLATION: CAUTION: Do not touch the bulb glass with fingers or other oily surfaces. Reduced bulb life will result.
  4. Install all of the bulb sockets in head lamp module.
Aug 17, 2009 | 2003 Jeep Grand Cherokee
1A Auto Parts 1995-1997 Chevy S10 Blazer Heater Core Logo
102 people viewed this question
Top 1A Auto Parts Home Experts
Vernon Taylor
Robert Plante
Are you a 1A Auto Parts Home Expert? Answer questions, earn points and help others
