Question about Eclipse Audio Players & Recorders
<!-- from fixya rte -->How do I charge the battery - Eclipse Audio Players & Recorders
  • Di Patel Nov 19, 2014
    Hi Kathleen Garcia, I want to help you with your question, but I need more information from you. Can you please say what it is that you want to charge?
  • 5 Answers
Most likely your device came with a cable for charging what kind of device do you have?
Posted on Nov 26, 2014
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
The lithium battery won't charge
If the lithium battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | Cameras
My battery will not charge in charger
The charge adapter may be faulty.
OR
If therecharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 14, 2012 | Nikon Mh-16 Digital Slr Camera Battery...
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
Problem in charging of dell inspiron 1525...on plugged in power it shows plugged in but not charging.. please give me the solution related to charging of the laptop..
If the charging LED is on but the battery is not charging then the battery may be worn out.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 16, 2010 | Dell Inspiron 1525 Notebook
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Phone won't charge
Hi, The Li-ion battery cahrging circuitary is some what complex. For most chargers, the charging procedure is divided into three main phases: ? Pre-charging phase ? Constant-current-charging phase ? Constant-voltage-charging phase In the Pre-charging phase, it utilizes low charging current to protect the battery. However,in most recharging situations, the charged batteries still have some voltage remaining, so the charger does not need to apply this action, and just passes it on to the next charging phase. The constant current and voltage charging phases are the main charging phase for recharging the batteries, where most of the charging energy is transformed into the battery. The maximum charging current for a battery depends on the battery?s rated capacity. For example, one battery rated 700 mAh usually can be charged at 350 mAh to 400mA, for faster charging effort. When the charged battery is Li-Ion, in the last charging procedure, the microcontroller normally maintains regular charging voltage while monitoring charging current to determine when the charging procedure should be completed. When the battery is fully charged, most of the electrical energy is converted to thermal energy, which can result in high battery temperature. In this case, the temperature monitoring function will be added for the solution. But since most Li-Ion batteries on the market also have an over-charging protection function, the temperature detect function is rarely used. So it is better to get your phone charging circuitary checked at a local store rather than to make a charger,coz both may cost you almost same. all the best my friend. regards sreejith
Jul 15, 2007 | Sony Ericsson K610i Cellular Phone
50 people viewed this question
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
Joseph Hoffmann
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
