Question about Garden
How do I change blade in the Black & Decker HT 22
I need to change the trimmer blade. How do I do?
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
SOURCE: Black & Decker Hedge Trimmer GT200 33 cm blade spacer
This is untried but I will use a nut for each of the spacers.
Thank you for your interest and follow-up support.
alanlec
Posted on Jan 30, 2010
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
  • 18 Answers
SOURCE: Black & Decker Hedge Hog 24-Inch Hedge
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Posted on Apr 29, 2010
How to change blade assembly on hedge hog 22
Are your blades dull, they can be sharpened. There is a good video on youtube by ereplacementparts where he shows you how to do it with a file and with a grinder.
Aug 15, 2011 | Black & Decker 22 In Dual Action Hedge...
Black and Decker 22" electric
I do not know of a reset. Most likely you damaged the wire and have to repair that section, or replace the wire.
If really helpful, please rate.
Jul 12, 2011 | Black & Decker Electric Hedge Trimmer
Plugged it in does not work
If it has been idle for a while, work the switch a number of times with it plugged in.Be careful of the blade! See if working it a few times will allow it to work. Good luck...Lee
Jul 14, 2010 | Black & Decker 3.8 AMP 22-Inch Electric...
Bought it today, it just stopped working. Worked beautifully for about 30 minutes. I would think something is caught in the blades, but that doesn't appear to be the case.
Check the blades very carefully! There can be a small twig, wire or most anything in there. Also, plug it into another extension cord to make sure the one you were using is okay. Good luck...Lee
May 29, 2010 | Black & Decker 3.8 AMP 22-Inch Electric...
Black & Decker Hedge Hog 24-Inch Hedge Trimmer. Motor runs, but blades don't move. Is there a sheer pin that I can replace, or is the thing bound for the dump?
Apr 27, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Electic trimmer
You're going to take off like 20 screws including the ones that hold the handle and the hood at the base of the blade. You open it like a clamshell. There is a black plastic cover at the very bottom that covers the gear wheels (one tiny wheel that comes from the motor and a large wheel that actually moves both blades back and forth). The black plastic cover is no attached with screws. You just remove it so you can get to the gears. Now you oil and manipulate the large gear wheel until it comes loose and you can see the blades move back and forth. Put the whole thing back together and you are ready to go!
Jun 12, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Need an online parts catalog to replace handle
This is actually a 2.6A Hedgehog 22" B&D: I found an excellent website at toolpartsdirect.com with an exploded diagram and easy ordering of the parts required.
Jun 04, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Mar 14, 2009 | Black & Decker 22" Electric Hedge Trimmer
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
