Question about Bosch Microwave Ovens
Hello Our bosch micowave-oven stops after 47sec after turning on microwave
    Master:
  • 423 Answers
I had the same problem with a GE Profile and it was the processor board.
Posted on Nov 19, 2014
  • 10 Answers
SOURCE: Pansonic Microwave Oven NN-S962-BF
Most likely the power capacitor is shorted.If you know someone that is just alittle familiar with electronics, they will know what to look for.The part will look like a somewhat long large silver 9v battery with two metal leads.Normally toward the back of the microwave and below the cooling fan.With a volt-ohm meter this capacitor can be checked.on the meter if you get a reading ,its bad, if you get no reading(open), its most likely good.Ninety percent of the time it will be bad.If it is, just replace with the same value and your ready to go.
Posted on Nov 06, 2007
SOURCE: Sick Microware
Ok easy one this, in actual fact your microwave cuts out after 23 seconds and not 22.
The problem is the magnetron.
HOWEVER I DON'T RECOMMEND YOU REMOVE THE OUTER CASING OR EVEN ATTEMPT TO WORK ON A MICROWAVE UNLESS YOU DISCHARGE THE INVERTER FIRST AS THIS HOLDS A HIGH VOLTAGE, EVEN WHEN TURNED OFF!!
Diver 1
Posted on Feb 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Purchased Bosch Combination Oven/Microwave Ref: E
Not sure on Bosch, since it's a non-US brand, but that may be a bad door switch.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Otherwise, you can get Bosch support here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
  • 12 Answers
SOURCE: REMOVING A RANGE MICOWAVE OVEN
Look inside the cabinets to see if there are any screws, as they act as anchor support, in supplement to the mounting bracket at the back of the microwave which supports most of the weight.
Posted on Jan 21, 2009
  • 6771 Answers
SOURCE: Bosch Microwave Oven
The problem is most likely a bad magnetron, "heart of the system" or the inverter board has failed, "if less than 7 years old"
Posted on Apr 19, 2012
A power surge at the clients house took out surge fuses on some bits of kit. We have repaired them. Now we are left with the bosch micowave with no power. Any suggestions?
If it has an invertor for the HV, return it to a Bosch Agent for repair but if it is a standard transformer, check the transformer supplying the control board.
Hope that helps.
Mar 02, 2011 | Microwave Ovens
STOP HEATING FOOD SOUNDS LIKE MICOWAVE IS STILL ON. STARTED SMOKING.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 24, 2010 | Kenmore 63792 Microwave Oven
Hi My Sharp R930AW has stopped working the tray does not rotate nor does the micowave come on
heatman101
Sep 15, 2010 | Sharp R930AW Microwave Oven
Micowave turn light is on but not heating..
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Sep 08, 2010 | LG LMV1680ST Microwave Oven
I turned my micowave on it ran for about 5 seconds then stop and showed a display error of f7
Hello :
Microcomputer board failure . You need to change the microcomputer board.
good luck .
please rate !
Mar 30, 2010 | Microwave Ovens
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
Microwave Oven model #JVm1850wd002 turn table does not operate or
Take off the case. You'll see two prongs on the door. If they are out of adjustment.And don't trip the contacts. nothing will work. Theres nothing mech on the turntable, the micowaves make it turn. Just make sure it turns freely,and is clean.
Dec 29, 2008 | GE Microwave Ovens
PANASONIC MICROWAVE MODEL NN524M
I have had many of these ovens and found it to be the Magnetron never try to fix a microwave yourself.
Jul 15, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
