Question about John Deere Garden
How do i check the oil in an electric john deere pressure washer
There is a oil view window on the compressor. Where should the oil level be? what kind of oil should I use?
    Scholar:
    New Friend:
  • 82 Answers
The oil should be visible in the window, maybe half way at least. I believe most oils should be a straight 30 weight that is non detergent, but i could be wrong. The dealership may be someone who could help you and give you the specs that you need. Just make sure you have the model # or they will give you the run around. Hope this helps
Posted on Nov 27, 2014
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
  • 61 Answers
SOURCE: My John Deere 2010 tractors lift does not work.
Here is a link to the John Deere web site for the manuals.
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&tM=FR&searchCriteria=2010&submit=Search&language=english
Also,
The hydraulics on a 2010 are part of the transmission oil system. There is a bolt looking plug on the right side of the transmission, about half way up, about where your feet rest when your foot is not on the brake. Fill up the transmission until the oil is level with the top of the hole and is about to run out. Using HyGuard hydraulic/transmission oil or one that meets the same spec for the 2010.
Posted on Sep 10, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
SOURCE: John Deere Gator XUV 2008 oil in gas
I know exactly the problem. I work for a John Deere dealership and have seen this problem before. It is called short-tripping. When a machine is first started, gas does leak into the cylinder and crankcase past the rings--normal--simulates leaving the choke on too long with a carburetor engine.. As the engine temperature rises, the gas in the oil is burned off and there really isn't a problem. When you take short trips or do not let the engine run to get it up to temperature, the gas in the crankcase does not get burned off and will accumulate over time. Make sure the machine is getting up to operating temperature and this could take up to 20 minutes if the ambient air temp is low. Feel free to e-mail at ericf@greensouth.com with further questions
Posted on Dec 16, 2009
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
Oil capacity
oil capacity 1979 Ford Thunderbird 5.8 litre
Jan 03, 2014 | John Deere 020297 Gas Pressure Washer
John deere problems
Have a pressure test done on the transmission to check for torque convertor /band/clutch adjustment. Check the oil cooler is not blocked from dust /dirt or other debris. Check oil level in transmission
May 25, 2013 | Cars & Trucks
I have the John Deer 3800 psi from lowes. The machine is in great running order it just seems to be losing psi as I use it. Also checking the oil in the Honda 13hp motor and in the pump. Do you take the...
Thread the dip stip back in to get a true reading of the oil level. Either oil filler may be used to top off the crank case. There is only one crank case - the oil on one side is the same oil seen in the other filler.
Apr 12, 2011 | Briggs & Stratton Garden
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 | Garden
1989 Ingersoll Rand 185 diesel compressor shuts down under load
most have safety shut downs built in, on the compressor side you will have a high discharge temp shut down, usually set to shut down @ 230 degrees F. normal temp should be @ 180F if it is running hot first check oil level on the compressor, and that the radiator is clean. some machines will have a thermostat that will only allow oil flow to go to the radiator after it comes up to about 150 degrees F. you really need to have a manual on the machine to see what other safety's it may have on the compressor and engine side as well.
Jan 08, 2010 | Air Tools & Compressors
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
My John Deere 2010 tractors lift does not work. I am note sure of the oil level. What is the correct procedure? Where can I get a free service manual to download?
Also,
Aug 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
