Question about Ricoh Office Equipment & Supplies
RICOH FT 4615,ANALOG ERROR 54. wHAT DOES IT MEAN?
I already check the fuser assembly. . and still the same...
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
First check if there are any soot of toner inside the fuser,you can either replace the whole fuser assembly or fuser thermofuse/thermister to solve your problem
Posted on Nov 27, 2014
fotobean
  • 103 Answers
SOURCE: On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Posted on Dec 11, 2008
  • 86 Answers
SOURCE: Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Good luck and please rate me, thanks.
Posted on Jan 21, 2009
  • 5 Answers
SOURCE: ricoh ft 3713 error 54
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
Posted on Mar 26, 2009
SOURCE: Replace Fuser error not clearing
Fuser PM reset
1. Hold the 'up' and 'down' arrows together for 5 seconds or longer.
2. Release the arrow keys and press the 'enter' key.
3. Select '2. Engine' - Then go to option '7.'
4. Go to SP7804-016 (PM Counter Reset>Fuser) and execute. Shows results=OK
5. Turn the machine off and on.
All done.
Posted on Mar 28, 2009
  • 95 Answers
SOURCE: Ricoh fuser oil replace message
That is not a good idea. The oil is kept track of by counting pages, not by a sensor that measures the oil level. The oil runs out and the machine can't tell and now you have ruined the fuser. Which cost a lot more than the oil tank.
Posted on May 26, 2009
Error 54.16 laserjat 3600
Hi
54.XX ERROR An error has occurred with one of the tonerlevel
sensors.
XX Description:
1. Que Make sure connector J1020 on the
DC controller is seated Correctly.
2. Replace the DC controller.
Dec 05, 2013 | HEWLETT-PACKARD Hewlett Packard Genuine HP...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Bleda kopja i posle zamene bubnja i developera.na ricohu FT 4615
Please in the english or in the francaise or ungarische for help .
Nov 12, 2009 | Ricoh Office Equipment & Supplies
Ricoh ft 3713 error 54
Mar 26, 2009 | Ricoh FT3713 Copier
I need the error codes for a Ricoh FT4222 analog copier - in particular ''E5'' when the machine is turned on.
You need to press the "*" (star) key to read the last 2 numbers, however all "5xx" are fuser errors. The fuser is not coming on, or not reaching full temp. It is either a blown fuse, lamp, or thermistor. The part(s) need to be replaced before the code can be reset, and a service tech is required to perform this in "service mode"
Mar 04, 2009 | Ricoh Office Equipment & Supplies
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
Error codes
Try to check the fuser section.
- Check the Lamp
- Check Motor Assembly
Sep 12, 2008 | Ricoh FT5832 Copier
74 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
