Question about Crosley Washing Machines
Crosley washer won't spend - Crosley Washing Machines
    Problem Solver:
  • 11 Answers
Its normaly the timer when that happens , check to see if it's running a full cycle
Posted on Nov 19, 2014
Whirlpool washer will not spend?
I assume that you mean spin. Check your belt and make sure that it is not broken. If it is slipping, do not use any lubricant on it. Replace it immediately.
Oct 16, 2014 | Whirlpool Washing Machines
Caws9234vq crosley model
Replace the pressure switch on the unit. Part #W10339251 for a description on how to remove machine cover reply to this message.
Jun 07, 2013 | Haier XQG50-11 Front Load Washer / Dryer
Crosley washer won't agitate
Hello Carroll Mcknight - Is the washer making a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the unit may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to assist with the repairs and to move forward accurately.
Jan 22, 2013 | Washing Machines
Crosley 5000 front load washer won't spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with either the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 24, 2012 | Crosley Washing Machines
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
My front loader won,t start it says dr when i press start
Your washer is sensing the door is open...your door lock may be bad....also make sure the dispenser (where you put the soap.....is closed also)
Oct 03, 2012 | Crosley Washing Machines
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Crosley 1244 washer won't cycle
This indicates a faulty lid switch.
Apr 27, 2012 | Crosley Washing Machines
Washing Machines Logo
42 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
