Question about BenQ Office Equipment & Supplies
Have Benq mx661 projector. When I use flash drive to show pictures, their order is changed. How do I project pictures in the correct order?
Changing the source from reader to documents. That didn t work.
    Top Expert:
  • BenQ Master
  • 22,688 Answers
Use a laptop.
Posted on Nov 19, 2014
Why do i have vertical lines on benq projector?
Probably because the signal going into the projector is a different resolution to the panel. The projector has an auto sync feature. But that only helps so far. Try changing the laptop resolution to match the native resolution of the projector (the pixels) and not the maximum resolution.
Aug 27, 2014 | BenQ Office Equipment & Supplies
Dust particles being projected onto screen with BENQ MP 525 projector
White spots on the screen are generally caused by a bad DMD chip.Multiple elements of the chip remain continuously on causing these spots.Solution is replacement of DMD chip.
Samr
Jan 14, 2013 | BenQ MP511 Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
The color of the presentation is distorted when it is projected from the BenQ DX660 Projector. It looks like the red is not coming through.
I I may have you try a simple test first, I have seen several no red problems fixed by changing or wiggling the vga lead to the computer. Also look for bent gold pins on the vga lead. I would do that first. Also go through the menu system and see if there is red in one of the icons on the screen to see if it is showing correct colour.
Good Luck!
Dec 17, 2009 | BenQ Replacement Lamp Projector Lamp For...
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
Benq w5000 green horizontal line flickering at bottom of screen
Hi there
This is normally only one of two things : Cable or Mainboard
The W5000 is quite a new Projector and should still be under warranty.
But try changing the cabling first and if the problem still persists , let BenQ replace the Mainboard.
Aug 30, 2008 | Televison & Video
Benq 6110 - mounting projector onto ceiling
You need to navigate to the 'advance' menu and under the 'mirror' setting select 'ceiling front' or 'ceiling rear' depending on whether you are front or rear projecting. It should all be on page 29 of the manual.
Hope this helps
Matt.
Apr 01, 2008 | BenQ PB6110 Multimedia Projector
Pip position
Hi there
The PIP ( picture in picture ) is only to determine where the Menu block itself will show on your screen.
Try the Vertical and Horisontal shift in the Menu Options.
Oct 23, 2007 | BenQ PB6100 Multimedia Projector
63 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
