Question about Kodak Office Equipment & Supplies
Hi, my dad's Kodak Brownie 8 A15 regular 8mm film projector has an issue with the knob. It will turn to the rewind position but not Project. Does it have to be pushed in ? I hate to force it.
    Problem Solver:
  • 10 Answers
Http://www.grantmillar.net/kodak-brownie8-manual-15-g-version1.pdf. Doesn't seem to need it. Check to make sure the knob hasn't turned ie off is project and rewind is off and there is another setting after rewind.
Posted on Nov 19, 2014
2 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Kodak Brownie Super 8 Projector
in slide projector smooth movement of mechanism is rule number 1 .1-spray contact lubricant cleaner on forward and backward switches and press them many times.-open it and clean it with air blower and clean piece of clothes.apply good type of light grease in levers-cams gears-confirm all mechanical parts is in good condtion.change any broken part from nearest store.
best regards
Posted on Mar 01, 2008
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
Have split image when watching 8mm film video.
If my memory serves me correctly, you should have an adjustment knob somewhere... and it seems like it was marked "frame". Another caution: I assume you know that 8mm and Super 8mm are not interchangeable. However, some of the old projectors (like a Kodak I had) had a twist knob that would change the projector back and forth in order to play either film. Just some thoughts...
Dec 06, 2013 | Computers & Internet
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
it is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Oct 13, 2013 | Kodak 1950s/60s Brownie 500 8mm Movie...
Control knob on kodak brownie 8 will not turn
Hi Don,
I have the same problem with my dad's Brownie 8 Model A15 projector...however, the knob will turn to "Rewind", but not to "Project". Did you ever get yours to work? Thanks! Jon
Sep 02, 2013 | Kodak Cameras
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
I want to know how to rewind a film reel or reverse an Elmo FP-A movie projector. I have an old Elmo FP-A movie projector that works fine. I do not have the instruction manual that would explain how to...
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Mar 10, 2009 | Fuji Photography
best regards
Feb 20, 2008 | Office Equipment & Supplies
223 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
