Just bought a 2 bed duplex was wondering how much it costs to get gas fired central heating installed it already has dimplex electronic heating
    New Friend:
  • 4 Answers
Idk
check the websies
Posted on Nov 19, 2014
2 Suggested Answers
sales50056
  • 72 Answers
SOURCE: I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Posted on Nov 30, 2012
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
1-888-346-7539
Monday - Friday
Nov 28, 2012 | Dimplex DS4411 Electric Heater
I need to change the bulb in a dimplex brayford electric fire, how do I get the fake coal plastic off.
The plastic ember bed lifts out with a little effort. To assist you, I have included a link to your Bradford model Owners manual that you can download and print for future reference.
http://www.dimplex.com/customer_support/technical_and_troubleshooting?docsearch=GDS26-BW1052&type=&dlang=
Dave, I hope this helps you.
Apr 29, 2011 | Dimplex Compact Electric Flame Stove...
How to change bulbs on Dimplex HTN 20
If you have a compact fireplace in a cabinet mantle, you will need to remove the front Plexiglas and frame from the front of the firebox. Remove the logs, then the 1- piece ember bed (it just lifts out). This will give you access to the light bulbs.
If you what looks like an old wood stove, you access then from the rear of the unit. Remove the bottom access panel by unscrewing the 4 screws that hold it in place. You can then reach the light bulbs to change them.
In both cases, the replacement bulbs are small base chandelier bulbs.
Hope this helps to solve your problem.
Mar 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
High running costs for gas fired Rayburn central heating
these are now a redundant range parts are no longer available and a good thing too as they cost the earth to run. gas ones cost more to run than oil. try "top of the range ltd" for a solution
Dec 20, 2009 | Kitchen Ranges
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
