Question about kawasaki Garden
Accidently pulld plug wire out of coil.dealer said just push straight in.;;;; it is a 422 14hp kawasaki in a john deer lawn mower
    Sergeant:
    Champion:
  • 253 Answers
Just push it back in
Posted on Nov 20, 2014
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
Howto change coil on a kawasaki 422 in a jd 240 mower
use some sort of lube like silicone spray
Nov 18, 2014 | kawasaki Garden
John deere stx46 won't move in forward or reverse
There is a handle on the rear of mower make sure it is not in the free wheel position. If so push it in and it should move. If not seek out an authorized dealer to test your tranny. Also check that your belt didn\'t break
Aug 03, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Jun 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
JOHN DEERE LX172 has no spark replaced coil still no spark why?
take the wire that goes to the coil off and try it if you have spark with the wire off the problem is with a safety switch or wiring
May 18, 2012 | John Deere Garden
JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Apr 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
48 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
