Question about Winter Sports
How do i remove a primary clutch on a 1973 344t massey fergusson ski-wizz snowmobile?
Does the clutch thread onto the crank? the outer shiv pulls off after removing the clutch bolt? I'm also curious if comet style clutch can be upgraded?
  • 196 Answers
No, it does not thread on. You just need a large 3 jaw puller. It is pressed on. Pretty easy to pull off with a puller and a socket. Depending on the clearance you have between the outer surface of the clutch and the side of the belly pan, you may need to unbolt the engine and lift it to gain clearance.
Posted on Nov 19, 2014
Ski replacement
take your pick :>)
Snowmobile Skis (Universal) - BikeBandit.com
www.bikebandit.com > Aftermarket Parts > Tracks & Skis Items 1 - 20 of 20 - ... at BikeBandit.com. The Web's most trusted source for Snowmobile Skis (Universal). ... AFTERMARKET PARTS · Shop Aftermarket Parts by ...
Camoplast Camoski Plastic Ski Kits ' Snowmobile Parts ...
www.mfgsupply.com > ... > Skis and Accessories. > Skis & Ski Shocks Camoplast technologically advanced blow-molded Snowmobile ski. Lightest weight ski on the replacement market.
OEM Snowmobile Parts and Snowmobile Accessories for ...
www.dirtcheapsnow.com/ Get your motor going with genuine OEM Snowmobile parts and aftermarket accessories at the best price for your Polaris, Ski-Doo, Arctic Cat, and Yamaha ...
Snowmobile Replacement Body Parts - Dennis Kirk, Inc.
https://www.denniskirk.com/snowmobile/replacement-body-parts Results 1 - 38 of 191 - Shop the best selection of Snowmobile Replacement Body Parts at Dennis Kirk for the lowest prices. FREE SHIPPING on orders over $89 ...
Aftermarket Ski Options - Snowmobile.com
www.snowmobile.com > Products Oct 16, 2008 - Aftermarket Ski Options: Most snowmobilers rarely give their sled's skis a second thought until that day when the sled seems to have a mind of ...
Jan 15, 2016 | Winter Sports
Where can we find a drive belt for a 1967 Massey Ferguson Ski Whiz snowmobile. The number on the old belt is 521965M2.
Hi Brenda:
I Googled the snowmobile gurus and this was on one of their comments.
Called my massey man again. He came up with a size.1 3/16x46 which would be the same as a LMX 1036.
Hope this helps.
Keep those old toys working!
Mar 07, 2015 | Toys
How do i remove a primary clutch on a 1973 344t massey fergusson ski wiz
Remove the main clutch bolt,thread in the appropriate clutch puller,tighten with an air gun,smack the end of the puller with a bfg! Make sure you obtain the right puller. you dont want to strip the threads out of the inside of the clutch or it will never come off.
Nov 18, 2014 | Winter Sports
Need instructions on replacing the whole clutch
Remove all tension from the cable. Drain the fluid and remove the primary outer cover. Remove the primary chain adjuster. Remove clutch adjustment plate cir-clip and plate assembly . Lock compensatory and clutch sprockets. Loosen and remove compensator and clutch hub assembly nuts and assemblies. Remember that the clutch nut is a left hand thread.
Oct 07, 2014 | Harley Davidson Motorcycles
Install stator
In order to install a stator on a Harley. You have to disconnect the battery and remove the outer primary. Then you have to remove the primary chain assembly, the clutch and the compensator nut and ramps to get to the rotor. Once you remove the rotor you'll see the stator. Compensator nut is 150 ft/lb. The clutch is 45 ft/lbs. The comp nut is standard thread while the clutch basket nut is left handed threads.
Nov 25, 2013 | Harley Davidson Motorcycles
How do i pull the clutch assembly on a 84 fxrs
Disconnect the battery. Drain the primary oil and remove the outer primary cover. Remove the four bolts that hold the clutch spring in. Remove the clutch spring and pressure plate. Then, you can remove the friction and steel plates. If you want to remove the entire clutch assembly, you'll have to remove the nut from the transmission mainshaft and remove the sprocket shaft nut. The mainshaft nut that holds the clutch assembly on has LEFT-HANDED THREADS. Once you get the nut off, you'll need a clutch puller to get the clutch assembly off the tapered transmission mainshaft. Get one of the pullers that screw onto the mainshaft and you rap it with a hammer. You do not have to disassemble the clutch assembly completely to remove it from the mainshaft. You can take it off as a unit by removing the snap ring in the center and removing the adjuster plate. Remove the sprocket shaft nut, the chain adjuster nut, and the mainshaft nut and remove the engine sprocket, primary chain and clutch assembly all together.
Good Luck
steve
Jun 10, 2011 | Harley Davidson FXR Super Glide...
How do you install a stster on a 2002 harley davidson electraglide
The stater is connected to the crankshaft on the left side of the engine
Drain primary oil
Remove outer primary cover
Remove clutch ,clutch hub (puller needed)
clutch hub is reverse thread
remove compensating sprocket on crank.
remove chain adjusting rubbing block
pay att. to position as if at the end of adjustment you may want to replace chain
remove chain with hub/sprocket
remove rotor
unplug wires from stator
remove stater.
you will need a clutch hub puller
check chain for wear replace if needed
check rubbing block for wear
Now Really Get a manual !!
find one here under other
http://www.repairmanualclub.com/motomanuals/index.php
Feb 08, 2011 | 2002 Harley Davidson FLHT Electra Glide...
Oil is coming out the clutch cable at adjusting threads what would cause this
Right where the threaded adjuster goes into the outer primary case, there's a locknut. There should be an O-ring on this treaded piece to seal in the oil. To replace the o-ring, you must go through the procedure to replace the clutch cable by removing the primary outer cover, disassembling the clutch release mechanism, and turning the cable out.
Good Luck
Steve
Aug 30, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
How to remove starter on a 2003 softail harley davidson
It's a lot of work.
First, disconnect and remove the battery. Don't want to lose a finger.
Drain the primary and remove the outer primary cover.
Remove the small bolt that holds the jackshaft onto the starter and remove it if you can. If it won't come out, you'll have to take the nut off the clutch assembly and slide it out just far enough to get the jackshaft out. To get to the nut, remove the clutch rod adjuster in the center of the clutch assembly by removing the snap ring. Loosen the nut, left handed threads. When retorquing 60-80 foot pounds, left handed. There is a coupling that connects the jackshaft to the starter, mark which way it comes out. Tapered end towards starter.
Remove the exhaust system if needed.
Remove all bolts holding the oil tank and lift it up as high as possible.
Disconnect the large battery cable and the small wire at the top of the starter.
Remove the two large bolts that hold the starter onto the inner primary cover.
Work starter out.
Mar 31, 2010 | 2003 Harley Davidson FXSTB Night Train
Need 2 replace clutch on my 2001 softail duece
Remove the outer primary cover on left side. Don't forget to drain the oil first. Using a large pair of snap ring pliers, remove the clutch adjuster plate from center of clutch assembly. Remove compensator sprocket nut (very tight) and the clutch hub nut (left handed threads) and remove nut from bolt on primary chain adjuster. Grab the compensator sprocket and clutch assembly and lift out of inner primary.
Jun 30, 2009 | 2000 Harley Davidson FXSTD Softail Duece
Winter Sports Logo
292 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
