Question about kawasaki Garden
Howto change coil on a kawasaki 422 in a jd 240 mower
Accidently pulled plug wire out of coil dealer said just push it in staight,no luck
    Problem Solver:
  • 11 Answers
Use some sort of lube like silicone spray
Posted on Dec 08, 2014
SOURCE: JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Posted on May 15, 2009
ChicoTico
  • 3 Answers
SOURCE: How do I verify spark is working?
There are spark (iginition) testers available, but the simplest way is to do what you are doing, plus a step. If you aren't grounding out the bottom "L" shaped part of the spark plug to a metal part of the engine, then you won't get any spark. So, here you go...
1. Remove spark plug.
2. Attach spark plug to wire.
3. Ground spark plug to metal (place the "L" on the engine block, etc... make sure no paint is in the way, it needs metal to metal contact.
4. Keep plug grounded and have a buddy crank the starter. That way you can really get a good look at the plug.
Best of luck!
ChicoTico
Posted on May 18, 2009
woobie dog
  • 1273 Answers
SOURCE: 1976 JD 214 lawn mower Kohler engine K321AQS
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Posted on Jul 19, 2009
SOURCE: 09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Posted on Jan 08, 2010
Testimonial: "thanks"
wolfepac
  • 27 Answers
SOURCE: JD 345 Having problem with ignition coil or
I have a Gx 345. Had a very similar diagnostic issue. Make sure you have a fresh set of plugs and have checked wires for abrasion. The best way to see, if you have a grounding out issue is to start tractor in the night and look for sparking on each side of engine.
Anyhow, after replacing ignition circuit board, the problem was corrected. Coils fail very rarly, if failed they simply don't work. Typically, an intermittant problem would point to circuitry or grounding issues.
Posted on Jul 09, 2010
My JD SX 320 misfires under load (one cylinder only)
plugs will not spark under compression if they are faulty or the HT lead id off too high a resistance. or mixture is incorrect
In the real old times when plugs were cleaned and tested one of the tests were to test spark in a dry compressed air chamber where if there was a problem they failed to spark
as you have fitted new plugs it comes back to the ht lead
they are carbon tracked lined internally, the connection for the plug and cap is just a steel pin shoved up into the carbon track
try using copper ht leads where the copper wire comes out to the connection
there could be a valve seating problem or weak valve springs on that cylinder that is not allowing proper seating under compression
if you have 2 carbies then the float level for that cylinder may be too low and under load starving for fuel
Jul 16, 2016 | Garden
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
No spark getting to plug on a F540v kawasaki engine
i can keep up with all the coils some need to be grounded out to get spark
Jun 18, 2012 | Garden
Hi
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Best of luck!
ChicoTico
May 18, 2009 | Garden
Apr 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
