Question about Hardware & Accessories
Iheater 1500 I bought a replacement switch but
Iheater 1500 I bought a replacement switch but failed to see how the install should be when I yanked out the old broken on. There are 4 section 2 white & 2 black wires that need connected. What order
Where did you get the switch from ?
Posted on Dec 01, 2014
  • 3,368 Answers
It is relative easy, check the switch contacts, you actually have two switches in one. Put the white on one "switch" the black on the other. You can check it with an ohm meter or continuity tester.
Posted on Nov 18, 2014
  • 2 more comments
  • Marc Mettert Nov 19, 2014
    So on one side both white and the other side both black?
    both white on the top and black on bottom, or white on one side black on the other side.
    got it thanks for the help Gil
Can the on/off switch be replaced? Ours broke off the back of the unit. This is an iHeater 1500.
Unplug the unit, Take out the old switch (You may need to open up the unit to get behind the switch to remove) and bring it to a hardware store or similar to match up. They normally have 2 connectors. Easy to do. Good luck!
Dec 21, 2016 | Washing Machines
My iheater (iH1500) seems to be missing a fusable link located in the back center of the unit. Can I get one to replace it. The unit doesn't power up.
If you believe it is not powering up because of a blown or missing fusible link, you can simply BYPASS the fusible link with a (large) piece of wire, briefly turning the power on to test the unit. If the unit powers up with the bypass wire (and it does not blow the fuse or breaker to that outlet)... leave the bypass wire there!
May 14, 2015 | IHeater 1500 Advanced Infrared Heater...
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
Jan 17, 2014 | IHeater 1500 Advanced Infrared Heater...
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
Replacing a switch on a ceiling fan
Wall mount. Cut the power to the switch by tripping the breaker at the "fuse box". You will need help to see what breaker controls that lighting circuit.
Get new switch,remove old switch from wall mount and note the color coding of the wires.
There will be screws that attach the power wires to the switch and
wires that go to the fan.Power wires are one black and one white. The other wire is a green ground wire.
Remove the wires,one at a time and connect to the switch,IF there is enough wire length to do so.You will need pliers to yank the wires out.
The stripped,bare wire at the end should go on the new fan switch so when you tighten the wire end,the wire end tightens onto the terminal clockwise.
If the stripped end is broken off,strip another 3/4" of wire and wrap the wire around the terminal,clockwise.
You MAY test the switch B-4 you put it back into the wall.Be careful of the "hot" black wire.
Click the circuit breaker back off and install into the wall box.
Jan 18, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a 4 year old Advantium 120. I bought it for $685 and had no problems x 4 years. Now renting the house and the unit stopped working. The repairman says there are two switches and a thermostat which...
Considering the possibility that replacement of the switches & thermostat may not solve the problem, I would likely look into replacement. Unfortunately, microwave repair parts are expensive and non-returnable.
http://www.repairfaq.org/sam/micfaq.htm has a section on this decision.
Also, broken units still have some resale value.
Mar 03, 2011 | GE Microwave Ovens
I have a 2001 town and country and yesterday I was driving went to turn left and steering locked up on me. Since I was in a turning lane I couldn't stop or pull over I had to yank the steering wheel and I...
i would take it to a service center that does a ,,,free,,, under car inspection,,so it doesn't become a safety issue,,,& you will know whats broken,,,
Apr 28, 2010 | 2001 Chrysler Town & Country
Hardware & Accessories Logo
200 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
