Question about Blue Rhino Gad860sp LP Gas Outdoor Firebowl with Slate/Marble Mant
How to replace the thermalcouple on the GAD860SP LP Gas Firebowl
I tried all the troubleshooting suggestions. Called helpdesk and they determined it was the thermalcouple which was still under warranty. Sent me a replacement but there were no instructions on how to replace.
    Top Expert:
  • 25,706 Answers
If under warranty, they should replace it or at least, if you agree, send detailed information.
Posted on Nov 19, 2014
Hot water heater pilot will not light
You have red wires connected to bottom of gas control valve?
Is this a power vent model?
What model, what brand water heater?
Is new thermocouple is finger-tight plus 1/4 turn and not shorted against gas control valve?
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Copy following link for safety magnet:
Magnet will click closed when pilot is turned off. Put butane lighter on end of thermocouple and listen for clicking sound.
http://waterheatertimer.org/pdf/Safety-magnet-Gas-control-valve.pdf
Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Bad gas control valve:
Low gas pressure, air in gas line, inadequate air supply, clean the air intake, tripped FVIR system, etc.
Aug 28, 2012 | Water Heaters
Sent it off to have motherboard replaced and now that i have it back it dosent reconize my 2.0 usb devices
Since you sent this to a shop, or manufacturer, I advise contacting them to determine the reason for this; as their work should be under warranty, and you should be able to get this fixed under that warranty.
Please let me know if you need further assistance.
I do suggest one thing - try using a different USB port until one does recognize it. If this does not work, then try shutting it down. Plug in the unit for which is not recognized, then start the computer again. At this point if the device/unit is not recognized still, contact the place of which you sent it.
carsandcomps,
Brandon
Aug 19, 2011 | Dell Studio 1737 Laptop
Pilot won't stay lit, replaced thermalcouple but
I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
May 06, 2011 | Rheem Water Heaters
When restarting my water heater the burner goes out when I turn the heat up. I have replaced the thermalcouple. According to the manual the next option could be a Combustion shutoff system was tripped. ...
The FV lockout varies by brand of heater... some require simple cleaning, while Rheem requires part
Following link has rundown for various models:
http://waterheatertimer.org/troubleshoot-flammable-vapor-on-gas-water-heater.html
Burner going out could be FV lockout, low gas pressure, or gas control valve thermostat:
Following link has troubleshoot for pressure and various models of gas control:
http://waterheatertimer.org/troubleshoot-gas-water-heater-thermostat.html
Oct 23, 2017 | Rheem Water Heaters
I have a Ativa DQ60M Paper Shredder and it is very clogged with paper and it looks like some of the blades are slightly bent. Can it be sent in for repair or warranty?
Take away info: 3-year warranty on cutter.
Office Depot item #405935: Ativa DQ83M Diamond-Cut Shredder (mine show model ...Mn. It has a 1-year warranty for product, BUT ALSO a 3-year warranty for the "cutting cylinders". Call 1-877-777-HELP; www.ativaproducts.com .
I called 12-29-2010. Rep had difficulty finding product, put me on hold, found it. Said prod only has 1-yr w (per Office Depot online, this is all that is given as to info); but I said, no, 3-yr on cutter. I held again, rep researched and agreed. I took a case number and tried rep's troubleshooting suggestion: I put 3-in-1 oil (veg oil suggested by rep too) on the jammed shredded paper (machine still would go in reverse BTW); I let it soak 5 mins, removed paper, tried shredding, and paper jammed again. No replacement parts are avl. I called again, gave case number. Rep suggested I oil the cutter now that paper was removed. I said cutters are oiled from removing paper. I was put on hold, only a short while.
Good outcome thus far: I was given fax number and instructions to receive gift card in 6-8 weeks upon their receipt of my fax (to 1-888-561-0785) of case number, name (first and last), mailing address, and copy of the receipt.
What I learned: Do the maintenance oiling monthly or more if needed! Try to buy a shredder that is beyond my shred needs, e.g., a 10-sheet cutter but use it only up to 8 pages. Try to buy a shredder that has replacement parts.
The price of the Ativa in 2008 was $40 ($30 instant savings taken at the register), and it didn't get daily or regular use.
Good product support on this Ativa product. Glad I saved my manual and receipt!!
Dec 22, 2010 | Office Depot Ativa DQ60M Shredder
Blue Rhino Gad860sp LP Gas Outdoor Firebowl with Slate/Marble Mant Logo
64 people viewed this question
Top Blue Rhino Home Experts
john h
Tom Chichester
Are you a Blue Rhino Home Expert? Answer questions, earn points and help others
