Question about Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011
Could any one tell me how much does it cost for a thermostat . For a ml350 2006 ?
My blower works . The heat does not ! It stay cold in the car and the windows stays fog .
  • Mercedes-Benz Master
  • 14,411 Answers
Hi Daniel,here's a link to your thermostat. Duralast Water Outlet 66812 at AutoZone com
Posted on Nov 19, 2014
I have a heating problem with my 2007 Ford Freestyle, the blower works okay but I have to run it on number 4 at full blast for anything to come out and then only cold air blows when the heat is on.
Check your antifreeze level. Never open the radiator when it is hot! always fill through the radiator reservoir. If that is ok, could be a sticky thermostat or a defective temperature sensor.
Feb 08, 2016 | Ford Cars & Trucks
Fuse for heater in 2006 Ford Escape
Replace the thermostat and if that doesn't work have the heater core purged of its air while engine is at normal driving temps. Have this done professionally or wear really good gloves do that you don't get burned.
Feb 17, 2015 | 2006 Ford Escape
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
96 Integra blower works but limited heat produced
It sounds like the engine coolant thermostat might be stuck in the open position, if your heat gauge is reading cold that is likely the problem...You should be able to find a you tube video about changing the thermostat, it's fairly easy.
Dec 23, 2013 | Acura Cars & Trucks
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
In my 1994 1500 Chevy pickup the heater blower will not work. Need to troubleshoot.
There is not enough information to answer you question effectively. Is your heater blowing cold air or is your blower motor not working? A tell-tale sign of vehicle blowing cold air is bad thermostat. Also, check your fuses under the dash first and fuse relays under the hood before proceeding with the thermostat change. A worst case scenario could be your heating/cooling controls have malfunctioned.
Jan 04, 2011 | Chevrolet 1500 Cars & Trucks
Car blowers are blowing cold air.
hi sharon
try changing the thermostat.it is probably stuck in the closed position. it is located at the end of the large hose that comes out the top side of your radiator. wont cost much for a garage to do it for you
Oct 25, 2008 | 2000 Ford Focus
Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011 Logo
51 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
