Question about Dream Maker Spas Pool & Spa
Spa wont turn on,there was a lightening strike.could that have ruined the spa
Won't turn on
  • Dream Maker ... Master
  • 1,338 Answers
Check the GFIC trip it and reset it, next see if any lights come on in the spa. if no you might want to check for voltage at the spa, if you have the set voltage 115 OR 230v . I would check fuses on the control panel .
Hope this gets ya running again. ask if you need morwe help, and don't forget to vote if i was of help
Posted on Nov 25, 2014
  • 11 Answers
SOURCE: spa drains when turned on
The problem is in your plumbing. Someone put a valve in an incorrect position. I would have to see a picture of your plumbing but if you can follow the flow of water. When you put it in spa mode, look at which valves turn and which ports open up. If it is doing anything other then sucking water from the spa and returning it only to the spa, then that is why it is draining. Again it would be great if you had a picture. What I have seen before is somebody plumbing in the pipe for a pool cleaner after the valve that send water to the spa. This would result in water from the spa slowly draining out of the pool sweep line. Good luck.
Posted on Jan 28, 2009
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
Posted on Mar 04, 2009
  • 3 Answers
SOURCE: layz spa pump
same problem I had so I seperated the globe by taking out the 5 screws around the middle then removed the nut from the hole the filter sits on its a strange fitting and must have a special key but I improvised by tapping it anticlockwise using a screwdriver and rubber mallet, once open identify the heater unit (it has a single wire going into it and is fastened to a length of metal pipe) and remove it by loosening the clamps at either side and pull the heater free, once free dismantle the plastic casing on the top of the heater inside you will see the live, neutral and earth wires, you can see the live (brown) wire goes to the water flow switch then the temp switch then the heater all I did was bypass the water flow switch by disconnecting the short wire from it going to the heat sensor and replacing it with the brown wire coming from the mains and it works fine now
Posted on Aug 02, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
How to get a ever flo to pump more oxygen
If you are asking how to pump more bubbles into the pool it shouldnt happen in the first place, if it does you might have a problem/you will soon(will ruin you alkalinity which ruins PH which ruins chlorine). If you are asking about a spa/jacuzzi, it should have a separate bubbler pump for it which will already be running at max if its working properly, check all connections/seals so air is not escaping.
May 26, 2015 | Pool & Spa
Morgan spa diagrams
The water jets in most spas are adjustable so you can turn the water flow down to just a trickle if you want to.
You don't take current spa jets out of the spa. They are held in place by a couple of tabs. Through the years the chlorine/bromine will deteriorate those tabs and the spa jets will start "popping" out when the jets get turned on.
If you pull the jet insert out the socket they are in, you will ruin the jet insert and it will need to be replaced.
Rod
US Parts Center Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 13, 2014 | Pool & Spa
My Marquis Randezvous Spa won't heat
It's one of 2 things. If the jets turn on but no heat, you have a bad pressure sensor or temperature sensor. If the jets don't turn on you have a bad pump.
Apr 02, 2013 | Pool & Spa
Jandy pool installation for RS8
1 check to see when you change from pool to spa the acuators are moving if not turn on or make sure wires not cut if not give me more info 2 make sure landscaping is on aux that is plugged in to relay if you need more info email me
Jun 21, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
How to replac bearings in century pool & spa motor
if bearings are bad motor overheating and ruining seals replace whole unit less hassle
May 10, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Which way do you turn the impeller to remove ir from the shaft. The part # is 310-4190. Thanks!
Counter clockwise looking at the impeller end. If you can't hold the motor shaft, you might try an impact wrench or using a socket and ratchet sharply strike the wrench.
Nov 15, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
Hada lightening strike in Backyard and it knocked out all the light bulbs in the yard including the pool lite. I tested the light itself it doesn not go on. Ever hear of this?
You should have some type of surge protection on that system. If it's plugged in somewhere check any outlets on that system for a GFI and reset it. That's all I can suggest.
Apr 26, 2010 | Hayward 12v LED Color Logic Pool Light...
After lightening strike, Aqualink control panel reads 6700 rev c. All lights on, none work. Outside, power center won't work. No lights. Reset doesn't work. Battery good, fuse appears good. Any ideas?
ok check all the braker even the one for the house .turn them off all and back on if this do not fix check for 220 v if voltage is present the board is bad need replacement get the number from the back to check for prices
Sep 05, 2009 | Jandy AQUALINK RS TELELINK KIT
Pool & Spa Logo
74 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
