I Have a Crosley front load washer model # CFW8000GBL that isn't getting power
Model - CFW4700LWO SERIAL- 4C31001977 crosley front load washer will not work in heavy load cycle. Times out after 3 mins and shuts off. Washer only works on casual cycle
This would be a control board issue, pull the panel apart and check for burned connector and circuit board overheating. If the control boards are showing signs of heat damage you may have a defective drive motor as well.
Mar 28, 2017 | Crosley Washing Machines
How do I access the drain pump on a crosley front load washer model number cfw4700lwo
Thank you for your post, derek dion!
From the information you have provided you need to know how to access the drain pump on your Crosley washer. I was unable to locate a step by step instruction sheet on how to access the drain pump. From your parts manual you would need to remove the front panel and it is located directly under the drum. If you are having trouble locating it or removing the front panel I would recommend contacting a professional technician for proper disassembly and repair. Best of luck! -OOS
Feb 22, 2015 | Crosley Washing Machines
I HAVE A CROSLEY FRONT LOAD WASHER AND THE DOOR WONT UNLOCK, I HAVE TOWELS INSIDE, HAVE TRIED RUNNING ANOTHER CYCLE, PLEASE HELP
I have had that happen a couple of times and by hitting the pause or cancel button a couple of times it then opened.
Mar 05, 2014 | Crosley CW6000 Front Load Washer
Crosley digital front load washer error code lr
Does it beep or flash any other lights? What was the cycle or setting it was in when this appeared?
Aug 10, 2012 | Crosley CW5000 Front Load Washer
Crosley washer cfw8000gw wont drain. checked filter, it is clean. now what?
go to the appliancerepairplanet.vstore.ca and get the manual on this and it can help u fix this
Dec 01, 2010 | Crosley CW5000 Front Load Washer
Owners Manuals
Where is the filter for my washing machine locate it??Hot point top load..It keeps leaving white stuff all over my dark clothes.
Jun 25, 2008 | Crosley CW5000 Front Load Washer
jus try to lubricate the lock n then try.... it wil work
Jun 17, 2008 | Crosley CW5000 Front Load Washer
Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
