Question about Necchi Sewing Machines
Necchi 00348 bobbin threaded but bobbin thread not being picked up in a stitch??
Every suggestion and illustrated in manual. Do the hawkers of the machine stand behind their product with support?
  • Necchi Master
  • 627 Answers
This is a normal problem for all sewing machines. It is called timing. While the needle is on it's way to the needle plate the thread is picked up by the hook(sharp, under bobbin). If the hook and needle aren't in the right position the thread won't be picked up. Open up your needle plate and use your hand wheel while you watch what happens with the upper thread as it rises. You should notice where the hook is while the needle is rising. There are are other times that the needle thread isn't picked up and that is when the hook isn't close enough to the tip of the hook. Now, you must go to you tube and learn how to time your machine. If this isn't something you wish to take on you can take to your local repairman.
Posted on Nov 19, 2014
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
i_luv_2239
  • 23 Answers
SOURCE: The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Posted on Nov 19, 2008
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
jpack76645
  • 23 Answers
SOURCE: needle will not pick up the bobbin thread, gets
Oh boy! I've worked on industrial sewing machines for over 30 years, but the home sewing machines are like comparing cadillacs to mopeds. No offense, but if you want performance out of a machine try an industrial. It will shock you with the difference. Be glad to help you find the right one.
Anyway, the problem you are having is quite common. First, make sure it is threaded right especially the moving spring on the needle thread tension) and the needle is new. This generally covers 75% of the problem. Make sure the bobbin thread is threaded correctly.
If you are still having the problem remove the bobbin/bobbin case and observe the needle/hook point relationship as you turn the handwheel. The hook point should pass behind the needle at the scarf of the needle (indention just above eye of needle) If it is not so the needle bar may have moved up on you. Did the machine get jammed?
I'm not sure about the rod you're talking about but lets try this first.
Posted on May 18, 2009
Hi. I have a Necchi MOD559. For some reason the stitches on the bottom stay too loose, so that I get little string hooks and not a clean tight stitch. From the top it looks great. Advice anyone?
Yep, It is called bird nesting or thread nesting. The number one reason is that the top thread is not seated completely in the top tension disk.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Confirm the thread path is correct.
Now recheck your machine stitching.
Remember if the thread issue shows under the fabric, it is a top thread problem. If the thread issue shows on top of the fabric, it is a bobbin problem.
If the top thread still shows on the underside of the fabric, you may need to tighten the top thread so it will pull the bobbin thread up.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
May 24, 2017 | Necchi Sewing Machines
Bobbin thread not being picked up Necchi 7010
This is a tough fix. There is a metal ring with a hook on it that goes around the bobbin. Check that there are no threads jamming the bobbin parts. Short of that, sry its a trip to the repair shop.
Nov 18, 2014 | Necchi Sewing Machines
Please tell me exactly how to thread the bobbin on a 3620. I have followed the instructions, but I don't have a picture showing the bobbin when finished. I start with the bobbin thread coming from left...
I also own 2 necchi sewing machines, I used to have a 3620 myself,,
in my operation manual it has a picture of threading the bobbin case,, if you would like a picture send me a comment with your email address
Nov 17, 2010 | Necchi 3620 Quilter Mechanical Sewing...
Adjusted the tension on bobbin, it won't sew a stitch just runs and no grabbing of the bobbin thread at all like you not sewing a thing.... adjusted top tension I am out if ideas.Help me please... The...
check the needle to see if it's damaged-roll on flat surface to see if it rolls correctly & also check the tip of the needle to see if it blunt or broke
check the bobbin to make sure it's not warped
make sure to keep a thread tail 3-5 inches when sewing
check to make sure the bobbin is inserted in the bobbin case correctly & the bobbin case is put in snug
if these suggestions don't work it may be that the timing is off & it would have to be serviced
Oct 01, 2010 | Necchi 3102 Mechanical Sewing Machine
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 26, 2010 | Necchi Sewing Machines
Where can i get my sewing machine fixed? i have a Necchi sewing machine, and it does not work. i bought it two years ago and it was working perfectly. i've tried everything it said in the manual, but it...
make sure you have it threaded right and picking up thread at bobbin
brfore sewing i have seen a lot of people put the thread the wrong way through the needle and it will have this problem
Dec 31, 2009 | Necchi Sewing Machines
Top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
Aug 22, 2009 | Necchi Sewing Machines
Zig zag stitch
If your stitches do not look good on the top side you have a problem with the bottom thread. make sure you have the correct bottom tension: Is the thread under the bobbin tension plate and when you hold the bobbin and case lightly in your hand the tension should be set in a way that there is little resistance , yet still some, when you pull the thread. After you set your bobbin tension, you may have to adjust your top tension to balance. Also make sure the thread comes off of your bobbin the way your manual tells you, clock or counter clock wise.
Make sure your bobbin (plastic) is not sooooo old, buy a new one.
Jan 14, 2009 | Necchi 6011
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Jun 25, 2008 | Janome D'cor Excel 5018
Needle picks up bobbin thread but then thread gets stuck
I had exactly the same problem on the exact same model 3205FA. I'm not an expert, but have a little experience on solving my wife and daughter's sewing machine mechanical problems. I would suggest the following: A. Page 6 of the owners manual see item # 1...to be precise it is 1 1/2 times around. B. Page 7 at the bottom, Make sure the bobbin tension spring is set so that there is tension. When holding the tread the bobbin shouldn't unroll. If jiggled about 2-3 inches the bobbin should release about 1/3 of that distance. C. Page 8 at the bottom, ill. # 2. There are two flange holders and screws that hold the bobbin case in position located at about 5 and 7 o'clock. Make sure both screws are tight. This is important. D. Make sure the thread is treaded through the upper tension adjustment properly. See page 9 # Illustration C. Terrible illustration. Keep the dial generally in the green range. E. Put in a new needle, the needles that come with the machine are just short of terrible. Wouldn't hurt to buy good top quality needles for the machine.
Aug 22, 2006 | Necchi 3102 Mechanical Sewing Machine
Sewing Machines Logo
53 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
