Question about Sanyo Televison & Video
Sanyo DP26640 has no power at all. It worked well for a little over a year and was plugged in with a playstation in the same outlet. No problems with the playstation. Wondering if buying a power boar
I've tried plugging into different outlets. Also unplugged and let it sit for days at a time. No power, no clicking, no noise, or sign of life at all.
    Novelist:
  • 126 Answers
If there's no sign of life at all, the power supply is probably dead. It may be something as simple as a blown fuse but not all of those are replaceable. If you're comfortable around electronics, you could open it up, check the fuses (there are usually two or three), and replace the bad one (probably the main power fuse) if you find one. If you're not comfortable around electronics, or can't find a bad fuse, you should try to find a TV repair shop if they even exist anymore.
Hope this is helpful! Good Luck!
Posted on Nov 18, 2014
melnavz
  • 1226 Answers
SOURCE: Plasma TV-power light does not come on
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
Posted on Mar 03, 2008
  • 5 Answers
SOURCE: I have the Samsung FP-T5084 50
Could be the PCB, but it is hard to say. I am looking for one that has a good screen since mine got cracked (don't ask LOL) so if you are interested in selling it let me know.
Thanks!
yrk2.7t AT (replace with @ symbol) gmail.com
Posted on Nov 08, 2009
  • 11 Answers
SOURCE: Panasonic flat panel just lost power while on,
Me the same some one please help!!
Posted on Mar 20, 2010
  • 8457 Answers
SOURCE: I have a panasonic plasma
This cause is the power supply board is dying,not giving the right voltage to the rest of the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 10, 2010
  • 145 Answers
SOURCE: TV was working fine. Shut it off, all power went,
ok you have done almost everything you can do with a no power on Tv problem, if you have the tech background you could try using a volt meter to see if the TVs power supply is getting the power it needs or if there is a lose wire on the power supply.
Also id check the warranty of This TV if you are within the warranty i could not take the back of the TV off if you are out of the TV warranty try opening the back of the TV and using a volt meter to test the power and check for any lose wires.
if you need anymore help let me know also please Rate
Posted on Jan 25, 2011
Testimonial: "Thanks for advise in regards to warranty."
Sanyo DP26640 LCD TV won't power up. Is there a fuse somewhere inside?
Every TV will have an AC fuse inside. This fuse can be located at its main power regulator [SMPS] board. This is a protection fuse; and if it is found burned [open], there should be sufficient reason for it. some kind of short circuit, or over voltage etc: Replacing this fuse without make sure, about the cause to burn the fuse; the newly inserted fuse too will fail, and more damage to set can occur. So, it is better to contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 22, 2016 | Sanyo DP26640 LCD TV
Is there any way to get audio out of the headphone jack to drive external speakers?
ONLY ON SMALL SPEAKERS, you can add headphone jack plug to any speakers an plug them in
Sep 17, 2015 | Sanyo DP26640 LCD TV
Whee is the analog audio output for sanyo dp26640
After reviewing the manual ( http://www.manualslib.com/manual/306783/Sanyo-Dp26640.html#manual - page 6), it does not appear that this television has an analog output. A fix to this problem would be to purchase a digital to analog audio converter (just Google this) and some inexpensive solutions are available.
Good luck,
Feb 04, 2015 | Sanyo DP26640ARB - 26 LCD HD TV 720p...
How come the power button to my Sanyo TV model number DP26640 would just quit working
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Oct 09, 2014 | Sanyo Televison & Video
My Sanyo DP26640 will not come on
Look for any loose contacts in power outlet.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Sanyo DP26649 26 in. TV
Tv has no power
Check power outlet and ensure there is power and correct voltage. Look for any jammed buttons on TV or on remote.
Jul 28, 2012 | Sanyo DP26640 LCD TV
Sanyo Model Number DP26640 Channel search
HI,
Did your problem solved. if you Need any assistance feel free to conact back.
Ajin
Mar 31, 2012 | Sanyo Televison & Video
Does my sanyo tv model DC26640 have a place for headphones?
Looks like your Sanyo DP26640 does not have a headphone jack in the traditional sense however it does have two audio output jacks (left and right) for RCA audio cables which would typically go to an amplifier with speakers. If you want strictly a headphone, what you can do is go to Radio Shack and buy an adapter cable for less than $10. You can get adapter cables for 3.5mm plugs and others. Plug your headphones in and you can listen. 3.5mm female and RCA male at the TV side.
Mar 06, 2011 | Sanyo Televison & Video
T.V. will not turn
try shocking  hit with open palm sides top. set on poss bad connnection. other wise prob not worth repair  sanyo has history of hor sweep circuit problems.
Dec 01, 2008 | Sanyo DS25390 TV
Televison & Video Logo
54 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
