My gas heater will light then once the house reaches temp on the thermostat the pilot light will go out and you can smell gas
  • 3,382 Answers
Turn it off and get a serviced person immediately. You should call your gas company before your domicile becomes pieces from the impending explosion. They will find the leak for you and probably recommend several companies that can repair it.
Posted on Nov 18, 2014
  • 41 Answers
SOURCE: pilot light wont stay lit once heater shuts off/ light goes off randomly
Hi Watertec00,
I am not familiar with this heater but it sounds like it could be a blockage in the main gas line into the heater or perhaps a blockage to the pilot gas line and maybe starving for gas. Best bet first is to check the main gas line from the heater. Easiest way to do this is to remove it from the heater and blow it through with compressed air. Then try the heater again. If that doesn't fix the problem then you can try blowing compressed air down through the pilot line. Could be a little dirt creating a blockage there. Then try the heater again. If it still does the same thing then try removing the panels to expose the heater's piping. If you can remove the main pipe into the heater from the gas and blow compressed air through it it should clear any obstruction from both the main line and the pilot. If this doesn't work then I would think you have a more severe problem and will need to take it to your local Heater Repairer. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
  • 234 Answers
SOURCE: Gas wall heater won't light
You need to bled the line longer and when you get lited hold down for a good minute.When the gas gave out ,there could trash in the line.I would take the line off and blow gas through it undtil you can smell it.
Posted on Mar 13, 2009
SOURCE: pro comm natural gas heater, pilot keeps going out
The problem is likely to be either the thermal-couple (easily replaced) or a clogged gas orrifice. The clogged orrifice would require a bit more know-how then the thermal-couple and with gas appliances it would be best to hire someone who knows what they are doing.
Posted on Mar 21, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my gas furnace pilot light goes out after reaching
The room air blower should have no effect on the pilot unless there is a crack in the heat exchanger. Do you notice a change in the pattern of the main burner flame when the blower turns on? If so, you have major issues. If not, it could be a dirty pilot orifice or a weak thermocouple.
Posted on Jan 14, 2010
atocrxr
  • 135 Answers
SOURCE: Pilot light can light and stay lit if I hold it
You have a possibility of two problems;
First:You need to check the pilot, when you areholding the pilot knob in, is the pilot flame covering the top of the thermocouple-the metal rod that is near the pilot, it will have a copper tube or maybe 2 wires, running back to the main gas valve. If the flame is covering the top 1/8" of the rod, it is ok. (For Now)
If the above checks out ok, now we move to the "Tip Sensor", this sensor is usually bebind the screen near the pilot knob. It has two wires running to it, the sensor is about the size of a dallor coin, inside this sensor is a metal ball, that makes contact with the two contacts inside the sensor, while the heater is standing upright, if the heater tips over, the ball moves and breaks the contacts in the sensor, shutting off the heater. This is a safety switch in case the heater tips over, sometimes the contacts in the sensor get dirty, try tapping the switch, basicly getting the ball to move around,then try it.
The final step - "Trouble Shooting purpose only", take the two wires coming to the sensor, cut them about 2" away from the sensor, and twist them together, then try it, if it works, the sensor is bad, take the sensor out, and shake it for awhile, then put it back in, rewire it to original wiring, if it still doesn't work, you will have to replace the sensor, contact the manufacture.
Please rate me, if this has been helpful, it keeps us keep on trying to help, LOL.
Contact me back if you have anymore questions.
Sincerely,
Paul Gibson
Posted on May 15, 2010
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
How do I light a pilot in a gas oven
On a pilot type system you typical hold an ignition source (lighter) to the pilot while holding down the thermostat (push the oven temp knob in) and hold for approx 20 seconds make sure you have the lighter directly on the pilot assemble in oven while you are doing this once it's lite continue to hold for the 20 seconds if you are not sure you are doing it right or if you smell gas vent your house and seek a knowledgable tech
I’m happy to help further over the phone at https://www.6ya.com/expert/william_e43a8a4d83a5f604
Dec 24, 2011 | Kitchen Ranges
How do i light the pilot?
Turn the Gas Control Knob inside the heater compartment from OFF to PILOT. Push in the knob and hold it, at the sametime push the ignitor button (will probably be a Red button). Once the pilot lights, continue to hold the Control Knob down for one minute. Then ease off of it. If the pilot stays lit, turn the Control Knob to the ON position. The burner should light, if the Thermostat is set higher than the ambient temperature in the house. If the Ignitor button doesn't work, you can match light the pilot. Just be careful and follow the instructions above, once it's lit.
Hope this helps solve your problem.
Feb 23, 2011 | Williams (5009622) Ceramic Gas Wall...
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
How do you shut down
the pilot light always stays on, its designed to allow your heater to turn on by itself without you needing to light a match every time. if the pilot light is burning you have nothing to worry about. its when the pilot light goes out that a small amount of gas leaks into the room. and by small i mean smaller than a hand held lighter... if you still want to shut the entire thing down you could turn off the gas line feeding the heater or possibly the whole house, otherwise the pilot light will stay on. as far as the actual heater turning off, thats probably controlled by some sort of thermostat somewhere. if you set the temp to very cold it should stay off. if that doesn't work then you may need a new thermostat.
Dec 31, 2009 | Vanguard International VN18B Infra-Red...
Code AGS, heater wont light
replace temp sensor for aqualink mounted in plumbing from pump
Mar 15, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
