Question about Refrigerators
How do i ? ive a 2012 chery j11 and iam unable to find any info on how to program the keyless remote for it please help regards Dan
2012 J11 chery
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
The Service Manual says this...
Remote Keyless Entry (RKE) Inoperative
No Response From Remote Keyless Entry (RKE) Transmitter
1. CHECK BATTERY
• Check battery of the RKE transmitter.
Is the battery voltage of the RKE transmitter normal?
Yes >> Go to the next step.
No >> This concern has been caused by the transmitter battery.
Go to step 4.
2. CHECK THE IGNITION LOCK CYLINDER CONDITION
• Check the ignition lock cylinder for proper operation.
Is the check result normal?
No >> Repair or replace the ignition lock cylinder key switch.
3. PERFORM THE RKE TRANSMITTER MATCH PROCEDURE
• Close all the doors.
• Insert the ignition key into the ignition switch which has lost synchronization in LOCK position.
• Press any button on the RKE transmitter within 5 seconds.
• Pull the ignition key out of the ignition switch.
• Try to operate the RKE transmitter.
Does the RKE transmitter operate properly?
Yes >> Erase all codes before returning the vehicle to the customer.
No >> Go to the next step.
4. PERFORM THE RKE TRANSMITTER MATCH WITH THE X-431
• Replace the RKE transmitter.
• Connect the X-431 scan tool to the Data Link Connector (DLC), press the POWER key to start the X-431 (use the most current software available).
• Turn ignition switch on.
? Enter the Diagnostic Program.
? Select Chery main program.
? Select diagnostic version.
? Enter download program.
? Select T11 series, and then select ISU.
? Select Remoter Match.
• Press the lock button on the RKE transmitter for less than 2 seconds.
• Pull out the ignition switch.
The concern was caused by the RKE transmitter.
No >> Replace the FBCM (See FBCM Removal & Installation in Section 15 Body & Accessories).
Refer to the RKE transmitter match procedure with X-431 as the description.
Perform match between the RKE transmitter and FBCM with X-431.
Best wishes from another Chery J11 owner.
You can download the entire service manual from the link below.
Kevin Mullen
Perth WA
Chery Tiggo 2009 Service Manual Page 1699
Posted on Nov 27, 2014
THE MACHINE INDICATE J11 WHAT IS THE PROBLEM
j11 indicates that the paper is not being fed from the paper cassette 2.
This can be caused by incorrectly loaded/thick paper. Cassette not correctly adjusted.
Paper feed rollers need to be cleaned or replaced. Blockage or parts failure.
Mar 24, 2014 | Kyocera Copystar CS-1635 Copier
Cheryl j11 radio beeps and says t p lost
Chery J11 radio beeps and says TP Lost
The Short Answer
This can be pretty annoying as the beep occurs every few minutes. The cause is that the advanced features of the radio are searching for broadcast traffic information, and can't find it.
Generally, only some of the radio stations in major cities carry traffic information, so this feature may not be very useful to you anyway.
To disable the beep, press the TA/AF button on the radio for more than 2 seconds, and you should see AF OFF appear on the display, meaning that the Traffic Announcement Alternate Frequencies feature is no longer searching for (and not finding) traffic information.
Unfortunately, the Chery radio manual doesn't fully explain this.
More...
Traffic Information (TA) Control
Some stations broadcast on the FM waveband have a TP code to signify that they carry traffic programme (TP) information. This is part of the RDS (Radio Data System) used on FM.
Activating traffic announcements
Before you can receive traffic announcements (TA), you must press the TA button. A TA display will appear to show the feature is switched on.
Note: On some units a short press to reach the TA feature.
If you are already tuned to a station that broadcasts traffic information, TA or TP will also be displayed. Otherwise the unit will search for a traffic programme and display TA SRCH or TP SEEK while doing so. If it cannot locate such a station, Not Found or NO TA will be displayed.
Info from
https://www.scribd.com/doc/60900285/audio-guide-1-cg3508en-01-2006
TP lost
If the TP signal of tuned station is lost after 30 seconds, an automatic TP seek for the next TP station will be performed. If no TP station is found, the unit will remain at the current station and display "TP LOST" for 2 seconds, and emit a beep.
TP seek will be performed periodically few minutes until a TP station is found.
Info from http://www.ryedalegarages.co.uk/data/uploads/docs/kia_venga_owners_manual.pdf
Posted to
http://www.cars-directory.net/problem-solving/chery/chery/11154.html
audio guide 1 cg3508en 01 2006
2011 Chery Chery Solving Car Problems chery
Sep 18, 2013 | Car Audio & Video
Chery j11
What To Do When : WIN appears on the dashboard of a Chery J11 SUV : Easy fix just a push of a button...Push the little button with the snowflake on it, it is to the left of the gear shift. This button allows the car to accelerate in 2nd gear in snow or icy conditions. It is also only to be used for this purpose any other use of this switch will burn the gear box out as the internal temperature will become critical fast.
May 29, 2013 | Cars & Trucks
How to reset chery service light model j11
how can i reset the service light on 2011 j11 2.0 chery
Mar 26, 2013 | 2009 Nissan Altima
Creaking handbreak cable on chery j11 even when off and driving
Your cable could be sticking, check it out and the rear brakes too
Mar 16, 2013 | Cars & Trucks
Driver sound laptop toshiba satellite j11
Hi Friend,
Kindly copy and paste the Link u can collect your sound driver
link is http://drivers.softpedia.com/progDownload/Toshiba-Satellite-A215-S7472-Realtek-Audio-Driver-6-0-1-5433-Logo-Download-41853.html
Once u Copy paste the link u get the page and then click the download_bullet.gifExternal Mirror 1 u will get the Download of the Sound Driver
Regards,
Ayyasam
Jun 03, 2009 | Toshiba Satellite M35X-S114 Notebook
Require wireless driver for T60H677.06
According to Toshiba's website, the Dynabook Satellite J11 uses the Intel 852GM chipset. Therefore, I would suggest you go to Intel's website (at this link). Then, choose your Operating System. That will lead you to the page with software and drivers for your laptop's chipset -- including the network interface card (NIC).
I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
Char1ieJ
Nov 23, 2008 | Computers & Internet
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
