Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
How do I get the volume to work, it doesn't work manually or with the controls
The controls work to change the channel and on and off but not the volume, even manually trying to turn the volume on it doesn't work
    Top Expert:
  • Panasonic Master
  • 74,136 Answers
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Nov 19, 2014
2 Suggested Answers
spr1949
  • 1182 Answers
SOURCE: I have a Panasonic TH-42PX50u that suddenly is stuck on one channel and no volume control either. Same whether using remote or on TV. Only turns on and off no other control.
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable. Look for jammed buttons on remote and/or on control panel. Try removing the batteries from remote and operating from the control panel of TV. If these are ok, Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Posted on Aug 06, 2012
No channel set up
Hi, try pressing the "closed caption" button on the remote. I hope that works. If this doesn't work try getting your TV's SE-R0305 Operating manual and reading through it and it might be able to help you. You will be surprised at how much information is in the TVs manual.
Oct 07, 2012 | Toshiba SE-R0305 Remote Control
Is there any way to get my tv channel back on 4 with no remote?
Try after amke a factory reset to your tV. Normally, aits remote control is needed to make it channel-4.
Apr 29, 2012 | Televison & Video
I have Aiwa TV MODEL No. TV-A219 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its
Hello
Check your remote control hanset for proper functioning. Get into this link to know more about the faults and repair to remote contorls.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
If remote control functions proeerly, the front panesl switches to be suspected. If any one mong the microswitches inside got strucked, all functions will be distrubed. it will be best to follow any more after replacing these microswitches. These switches can be located just behind the control panel of the tv, soldered diretly to a printed circuit board. You have to replace all of the at the same time. Just undolder one amoung them as as sample, when you go to buy for a new one.
If this also does not help you, repalce its memory IC. This IC can be located very near to the main system control IC, will have 8 solder terminals. A very small IC and wont cost more. Eventhough it is very small, function of it when the set works is great. Replace it. When you buy this IC, make a keen look on it number. It is very important when replacing this IC. All these components stated above, can be bought from most of the electronic spare part selling shops st your town. OK.
Feb 07, 2012 | Aiwa TV-S2011 20"
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
I have just bought an Behringer EP4000 amp. How do I connect 2 x B1520 and 1 x B1800X speakers to this amp? Thanks!
You don't (unless you want two B1520's on one channel and the sub on another). Reading the manuals would help.
The EP4000 amp drives only two channels. It CAN be bridged for one speaker but it won't support two channel and bridged mode simultaneously.
http://www.retrevo.com/support/Behringer-EP4000-Amps-manual/id/23591dj795/t/2/
The B1520 subwoofeer is PASSIVE so it will need a dedicated amplifier to power it and control its volume independently of other speaker channels.
http://www.behringer.com/EN/Products/B1800X.aspx
Aug 31, 2011 | Behringer Eurolive B212A Speaker
Dav-dx250 volume is very low with maximum volume
How does it sound when you calibrate the speakers (page 75)? THAT is how the basic hardware is verified. Anything that doesn't work after that is usually a setup or source issue. Read the manual.
http://www.retrevo.com/support/Sony-DAV-DX250-Home-Theater-Systems-manual/id/750dj491/t/2/
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Aug 18, 2011 | Sony DAV-DX250 System
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
How do you hook up a external amp to a yamaha HTR-5790 av receiver? Do you have to change any settings?
Elaborate a bit on what you're trying to do if this doesn't work for you.
This unit has Pre Outs near the center of the rear panel for all audio channels which will allow you to use external amplification for any speakers you wish to use and the receiver will still control the volume.
See #12 on page 10 of the manual. Try retrevo.com
Just run RCA cable(s) from the desired Pre-Out jack to the input(s) on the external amp with its speaker(s) attached. Set the external amp's volume (if it has one) to very high, then leave it alone. Run through the Yamaha's speaker location and volume settings to level-match the external speakers to the rest.
If you want to simultaneously use the Yamaha-attached speakers for the same channels as the external amp you'll have to match the like channel volumes to each other using a volume control on your external amp, then level-match them as a unit to the other channels.
Dec 23, 2010 | Yamaha Audio Players & Recorders
I have my bose v1 equalizer connected to my 3375 harmon kardon the following way.....equalizer(line output..to receiver tape monitor in) and equalizer (line in....to reciever tape rec output ....i am not...
I bet it would work if you listened to something 2-channel and analog. THAT is the limitation of anything that uses a proccessor (like the 901's) and modern AVR's.
Multichannel AVR's automatically disconnect digital inputs when a tape loop is activated.
Adding to YOUR particular problem is that the 3375 doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually
You COULD place some RCA Y-splitter cables where the Pre/Main jumers are and send a stereo mixdown instead of true front channel to the Active EQ and thence to a separate amp, but it's not true front channel. But you would have local control of the 901 volume after you calibrate them to match whatever other speakers you use.
When did they stop making AVR's with 7.1 pre-outs? My 9-year old Pioneer has them and I have 901's, 301's and a sub going.
Oct 15, 2010 | Bose 901 VI Main / Stereo Speaker
Fender Deluxe. The volume knob has no effect whatsoever. Volume only changes with the drive knob.
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here:
http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
Have fun - it's a great amp.
Oct 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
