Question about Bissell 39N71 Steam Shot Handheld Hard Surface Steam
Continuously Steams without touching trigger? Can this be fixed?
Once water heated, it starts steaming., touching trigger odes nothing? I love this machine but can it be fixed?
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Bissell Steam Cleaner
go to www.bisell.com/how-to-videos/ and use the respectively model and use the common sense for troubleshooting.
God bless you
Posted on Sep 07, 2012
When has my iron stopped steaming and heating up?
depends on how old it is, try to rinse it with a water and vinegar solution, this might help
Apr 09, 2015 | Euro Cuisine Ootoo Iron, 1500 Watt Steam...
Why has the steam function has just stopped working - power on but nothing happens
My wife has one of these irons and she loved it. Now it steams for a while, and a red light starts blinking and it stops steaming. It can be turned back on and works for a while, then the same thing happens. I read that it needed descaled, so I bought OUST descaler and ran it through the iron, but it did not solve the problem. Any one have a solution to this problem, I would like to hear from you.
Jul 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
Nov 14, 2012 | Irons
The temp gauge reads correctly for a while then it starts going from cool to hot faster the water can change temp. I have changed the sensor
try the thermostat, located on the top radiator hose. top side of engine. also does it steam?? does it lose water but no leak, does the heat blow hot? if your heat isnt hot and it steams and loses water you may have a cracked head or head gasket. if you have heat, doesnt lose water and doesnt steam it may also be your water pump. most pumps will leak visibly from the weep hole when running
Aug 02, 2011 | 1999 Dodge Caravan
Iron steams continuously even when staem switch set to off
Water still getting hot in there ,obviosly there is a problem with the switch or the liner in the iron just take the water out if you dont want it to steam
Feb 17, 2011 | Vacuums
The iron seems like it is on but no steams come out I will mess with the wire and then too much steams comes out and I have water stains
Power Cord is bad and power cuts on and off not allowing the proper heat. When power cuts off you lose heat and the iron fills up with water and not steam then when power returns you have to much steam.
Jul 17, 2009 | Rowenta Irons
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Tefal Pro Express Steam Generator Iron
Irons are generally not worth repairing. That said, try to clean out any mineral deposits with a mixture of 1/3 vinegar and 2/3 water. Put in the usual amount. Warm the iron, try to get steam. Empty the iron and do it twice more. Then, rinse it out with plain water.
You may get lucky!
Jan 21, 2008 | Irons
Bissell 39N71 Steam Shot Handheld Hard Surface Steam Logo
60 people viewed this question
Top Bissell Heating & Cooling Experts
Lawrence Oravetz
Tom Chichester
Are you a Bissell Heating and Cooling Expert? Answer questions, earn points and help others
