Question about Pool & Spa
Why is the "no flow" light flashing? The water in my 2 paper cartridge filter only comes up to the bottom filter and it is the only one trapping all the rubbish. The top filter is pristine. The pool i
Using Onga paper cartridge filters.
  • 3,368 Answers
Probably because the existing filter is plugged or the input line is plugged.
Posted on Dec 10, 2014
SOURCE: onga pool pump running but not drawing water from pool
Take out the pump pot basket and stick your finger in the hole towards the motor (make sure the motor won't kick on!!). What you should feel is the impeller. It has five grooves in the face of it and each one needs to be cleaned of foilage and debris. With every hole clogged in the impeller you lose 20% of your motors effeciency. With whisperflow brand the pump pot basket is poorly designed where debris like pine needles go straight through.
Griffin Pool Services
Las Vegas, NV
Posted on Jun 06, 2009
  • 11 Answers
SOURCE: Shocking
We had a similar problem with our pool. What kind of water are you using to fill your pool? Is it well water? We used well water which appeared crystal clear when we put it in the pool but after running the saltwater system one time we had very yucky water! So, we shocked it and this made it worse, a pea soup green color actually! I talked to the pool guy in town and he said it was probably from our water source since it's from a well and that we needed to put some Metal Out stuff in it first, which we did, and now we have perfectly clean water again, it worked great! I'd take a water sample into your local pool store, they should be able to help you. Good luck!
Posted on Jun 19, 2009
  • 83 Answers
SOURCE: Sta-Rite S7M120
The brown-green gunk sounds like algae. You stated that you have cleaned the filter. Have you taken the cartridge completely out? If not, I would suggest that you do so. Scrub the inside of the filter tank with a 4:1 bleach water mixture, only 1 part bleach. Then soak the cartridge in an acid bath, like Muriatic Acid. This will kill any algae that is in the filter itself.
You may need to vaccuum your pool to waste, get rid of some of the water and refill it. This may help get the chemicals in order.
Another idea would be to run the system continuously for a couple of days. Vaccuum to waste, not to return lines, and clean the filter when it reaches 8 to 10 PSI above start-up. You may not be running the pump long enough to properly filter water. Keep trying to get chemicals in order.
Posted on Jul 08, 2009
  • 93 Answers
SOURCE: We have green water...so green you would not be
you must shock with liquid shock along with a strong algeicide make sure you are backwashing every hour or two
Posted on Jul 17, 2009
  • 760 Answers
SOURCE: Dial a flow question
Ok the first on the PSV valve. the 1/2 position should really be 1+2. You have two linlets to your pump. One from the skimmer and one from the main drain in the floor of the pool. When you select port 1 it will be one or the other perhaps 1 would be skimmer and 2 would main drain. You can select one and see if the flow stops in the skimmer. That will tell you which is which, depends on how it was plumbed. Position 1+2 combines the two flows. I normally select both, If my pool gets a lot of grass and leaves, I select skimmer only or when I vacuum. I select main drain only when there is more debris at the bottom. OK recirc is only recirculating within the piping system bypassing the filter. You can dowload a complete manual of your filter and components from www.haywardnet.com. Green water: Ok your chemicals are right? Free Chlorine, total chlorine? hardness, calcium, pH, alkalinity? Well most pool companies want you to buy some algaecide and that can't hurt, but I'd shock your pool if it's dark green I'd put it 4-6 gallons of liquid chlorine, if its light green 2-4 gallons. This is when I'd use recirculate. Allow this to mix without filtering for a couple of hours. Turn the pump off and allow to set overnight. In the morning you should have much clearer water, with green slime sitting on the bottom. Vacuum this to waste very gently so as not to remix algee.IF this doesn't work you'll need som floculant and repeat the opeation folling the directions on the floculant Restart filter, keep chlorine level high above 5-10ppm for a day or two and keep filtering. If it is still cloudy now,add some filter aid. In hot weather, don't let that free level go below 4ppm. Don't allow anyone to swim while chlorene level is high. Be sure to us test strips that indicate free and total chlorine.
Posted on Jul 21, 2010
WATER LEVEL FLOAT DEVICE PREVENTS UNIT FROM TURNING ON,EVEN THOUGH WATER TANK IS FULL. REMOVED SOME FILTER MATERIAL WITH NO EFFECT. FLOAT IS FREE WITH NO RESTRICTION.
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
The intex fp621 4000 pool pump does not seem to be filtering the water. the water comes in and right back out but filter doesnt even get dirty and water seems to go in dirty and come right back out dirty....
Try making sure filter is installed correctly. Push filter down onto foot ring. Install cartridge support on top of filter with gasket into filter and fingers up. If filter is not seated on top and bottom, debris in water will flow around the filter instead of being trapped in it.
Jun 13, 2010 | Intex 4000 GPH Filter Pump
Low water flow
Low water flow is generally and indication that the filter is dirty / clogged. Remove the filter cartridge and see if the light goes out. Replace the filter if required.
Apr 22, 2010 | Intex Automatic Salt Water System for ...
No more steam. Want advice on disassembly.
There is info on the FAQs from Air-o-Swiss:
http://www.airoswiss.net/service/faq.aspx#35
Q: Unit is running intermittently.
A: How long has it been since the contents of the cartridge were replaced? If 2-3 months have passed, it is time to replace the contents of the cartridge. However the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit ceases operating at its full performance. If the contents of the cartridge were just replaced there are probably too many granules in the cartridge. Remove 2 tablespoons of granules from the cartridge.
Feb 20, 2010 | Air-O-Swiss U7142 Humidifier
Water will not flow out of dispenser
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Sep 07, 2009 | GE Refrigerators
Green and orange lights flashing
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
CF
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Out of paper light flashes even after paper is loaded
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Apr 25, 2009 | HP DeskJet 690c InkJet Printer
No paper light ligted even after paper is loaded
4. paper jammed
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
