Question about Infinity Kappa 10.7t 1'' M.M.D. Dome Tweeters Car Speaker
Car stereo crossovers
I've installed a 2 way speaker system in my car and now it's time to hook up the amp. The woofers are CDT mid range subwoofers and the tweeters are Infinity Kappa 10.7's. The tweeters come with what appears to be an in line bass blocking capacitor. I have some 2 way passive crossovers from MB Quart. And my Amp has an electronic crossover with a high pass and low pass filter on each channel.
My question is, can I simply use the electronic crossover in my amp with out using the passive ones....
  • 111 Answers
Re: Car stereo crossovers
You should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Posted on Nov 17, 2007
0 characters
3 Points
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
Testing this item
Depends on the mid-woofers you're using. I'd use the cross-over with the mids too first. Exparimenting won't hurt, just make sure the tweeters are run through the cross-overs or you'll smoke them quick.
Apr 18, 2010 | Kicker KS13 Car Tweeter
How do i wire the crossover on the dxd210/213
If the crossover is made to accept speaker level input from amp then.....Amp/head spkr output + to crossover + input. Amp/head spkr output - to crossover - input. Crossover midbass + out to midbass spkr + input. Crossover midbass - out to midbass spkr - input. Crossover vari-tweeter + out to tweeter spkr + input. Crossover vari-tweeter -3 or -0 or -6 out to tweeter spkr - input. You have to choose for your preference. 0db makes the tweeter respond normally. -3db mean 3db lower in volume...and -6 means 6db lower in volume. Choose based on your liking.
Apr 12, 2010 | MB Quart - 5.25" 2-Way Component Speakers...
Need to know how to wire a dual voice coil subwoofer
All a Dual Core Speaker is, is Two speakers, sort of, in one. It has Connections for the Mid-range and Woofer, so The Inner speaker, is the Mid Range and the Outer, is the Woofer. Wire + to + (Red to Red), & - to - (Black to Black)
Jan 22, 2010 | Soundstream PCS-12 Car Subwoofer
How to install 4 way speakers
Exactly the same way, you would for a normal speaker.
Four-ways combine a woofer, a mid-range, a tweeter, and a "super tweeter" into one speaker. But it should still only have one positive and one negative.
Jan 13, 2010 | Sony Xplod 240 Watt 6" x 9" 4-Way Speaker...
I have a 04 silverado do i need to install my component speakers in series or can i hook up woofer to factory wing and tweeter seperate from factory
With component speakers it is imperative that both the speakers be hooked up to the supplied crossover. Wiring them in series or parallel will not yeild satisfactory results since the woofer requires lower freequency then the tweeter, which plays the high notes.
Now some cheaper speakers do not use crossovers and sound rather poor. What make and model of speaker are installing? Does you truck already have component speakers in it?
Jan 06, 2010 | Alpine SPS-600C Car Component System
No sound out of tweeters, highs out of woofers?
it does sound like you shorted out your crossover which can be fixed if you know what you are doing, but in the long run i would try to get another one i know that raidoshack sells some small ones and is also cheap, if your positive that you didnt short out the crossover se if it needs power, see if you can cross your woffers and tweeters on the crossover, if not is there any settings that u can change on the crossover? hope i helped :)
Apr 28, 2009 | Jl Audio VR650-CSi Car Component System
CL-51 Braxial component
ok well do u have a amp hooked up on the speaker and if not u could have dust in there or it could be a blown voice coil in the woofer part it self best way to check is to take a cotton swab u use in ur ear andgo along the coil part the speaker u no the brownish looks like ornge wires sum thing like that and do it very gently swab around the coil let me no if that helps
Apr 05, 2008 | Cdt Audio CL-51 Car Component System
Tweeter and door speakers to fit a Lexus EX 300 w/Levinson factory system
I found that they can hold up to 6 1/2" speakers and 2" tweeters. I'm not sure the specific mounting depth but i can almost assure you there wont be any 6 1/2" speakers that require a whole lotta space
Feb 22, 2008 | Cdt Audio Eurosport ES-100 Car Tweeter
Infinity Kappa 10.7t 1'' M.M.D. Dome Tweeters Car Speaker Logo
655 people viewed this question
Top Infinity Car Speakers & Subwoofers Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Steve Sweetleaf
Steve Sweetleaf
Are you an Infinity Car Speaker and Subwoofer Expert? Answer questions, earn points and help others
