Question about Emerson 20" Pure Flat Screen Tv
My Tv will not turn on?
Plugging & unplugginh new batteries in remote. This has a small box installed by direct tv. I have contacted direct.cannot do anything since the tv will not turn on
If tv not powering on, then probly power capacitor is bad. Open tv to reveal inside. There is a cluster of small capacitors look like tiny cans) that feed/store power to turn on tv. If capacitors are bulging on tops then they are bad. Simple to replace by soldering. Can purchase online or radio shack.
Posted on Nov 22, 2014
Receiver Volume Control
TRY UNPLUGGINH THE UNIT FROM WALL PLUG SOCKET FOR 10 MINS THEN TRY AGAIN
WWW.GENUINEREMOTES.CO.UK
Mar 18, 2014 | JVC Remote Control RM-SRX888J...
Samsung universal remote control codes do not work with Verizon STB
you must call to the company for see what happen.
However clean the contacts batteries
2) change new batteries
3) resolder the wires contacts batteries
4) tight the spring contacts batteries with pliers for better contacts.
5) open the remote and clean the keypads with special spray contacts.
6) Try again.
God bless you
Jun 19, 2012 | Samsung TV Remote Control
My remote control is a model CT-90233. Several of
your remote is old and needs to be cleaned and rebuttoned(you can do this yourself) open up the battery panel and look for small screws to take of the case. you need to dust it out with compressed air. and reline the buttons. when you push down on the power button it probbaly is not making complete contact with the button, take a small thing and poke the power button without the buttons on. see if that works. if it turns on right away with direct pressure to the power switch then you just need to make sure your buttons are making complete contact. if that dont work then your circuit is screwed. you need a new remote or a new tv.
Feb 16, 2010 | Toshiba 32A30 32" TV
I need a new direct tv rca remote. I was told
disregard. I contacted Directv direct. They are sending me a new remote and I do not have to purchase a new box. The installer was wrong when he told me that.
Jan 18, 2010 | RCA Televison & Video
Direct tv remote batteries fail constantly
I have same problem with Dish TV.........I was told the 'fix' was to press satellite button, on the remote, after turning off the telly. There is no permanent resolution - Problem occurs as remote is always communicating with the box when it's in TV mode (which happens after you power off the tv).
Aug 29, 2009 | RCA DIRECTV Satellite Remote Control
Remote won't turn tv off or on. Mute, volume also does not work
Take the set apart and see if there is a separate board in front of the set. Remove the board and check for cold solder joints first. If o.k., replace sensor. Then again you could contact toshiba and order another key pad for the set.
Jul 07, 2009 | Toshiba 13A24 13" TV
When my sharp lc 32sb220u is turned on, my direct tv remote will not change channels. this just started. Nothig was changed. after this, i did change the direct tv box and it still would not change...
That remote has to work / it is a direct tv issue since it is their equipment that you are renting and it is supposed to work with your set..
Did you make sure that the batteries in the remote are good? that the remote unit itself is good ( Use digital camera or am radio to test out - see google)
Sep 20, 2017 | Sharp Televison & Video
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
May 16, 2008 | Sony KV-32FS13 TV
Toshiba TZ50V51
Small dog or large==coincidental/unrelated to problem!General service includes some very precise soldering==requires chassis pull. One or more micro-fuses will be bad and STK IC's should be replaced.Alignment in servicer menu may be needed after repair completed.
Oct 03, 2007 | Mitsubishi WS-55807 TV
Emerson 20" Pure Flat Screen Tv Logo
64 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
