Question about Caple Ovens
Caple C3242SS Double Oven. Fan rattling in Main Oven when turned off after cooking on manual.
Tired Auto cook, no rattle as oven turns off, when cold it's rattles for a turn of fan when turn on and off. after cooking on manual the fan in main oven rattles for about 10 - 15 sec to it stops, this is a brand new oven, only been used once! But had on on for a hour at high temp, still rattles when turned off
  • Caple Master
  • 3,382 Answers
Since it is new contact the people that sold you the oven for warrenty repair.
Posted on Nov 19, 2014
Testimonial: "Thank waiting engineer to get in touch, Caple are arranging one"
SOURCE: Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Posted on Dec 30, 2006
  • 1462 Answers
SOURCE: Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Posted on Mar 20, 2007
  • 1462 Answers
SOURCE: AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Posted on Sep 07, 2008
  • 200 Answers
SOURCE: Fan rattling in Hotpoint BS41 oven
Hi
Check this link
http://repair2000.com/oven.html
Posted on Sep 16, 2008
barkencoa
  • 3463 Answers
SOURCE: NOISY OVEN
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Posted on Dec 21, 2008
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
The fan on my neff oven is not working is this espensive to fix or should i get a new one
If you are referring to the fan in the main oven compartment, then yes, they are quite expensive to replace.
If the oven is more than 5 years old,then I would personally consider buying a new oven.
Make sure that the oven is set to manual cooking, and is not set on auto cooking.
Mar 05, 2011 | Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
I need the instructions for a diplomatic double fan oven as the second oven is set on auto timer and I can't get it to work.
i had the same prob..... manual operation, to set the programmer to manual (cancelling any auto setting),press the cook time and ready time buttons simultaneously.
To set time of day, press the cook time and ready time buttons simultaneously and keep the buttons depressed. Use the plus and miuns buttons to the the time. A(auto symbol goes out cookpot symbol comes on.
Mar 27, 2009 | Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Sep 07, 2008 | Ovens
Dec 27, 2006 | KitchenAid Architect Series KEBC208KSS...
Ovens Logo
135 people viewed this question
Top Caple Ovens Experts
NOEL
NOEL
Gil Shultz
Are you a Caple Oven Expert? Answer questions, earn points and help others
