. Why is my drive pulley locking up and burning belts?
Washer will run. Agitator stops. Drive pulley locks up and belt begins to burn. Shut off washer and turned pulley by hand. Got it past a really hard spot and then the waher will agitate again. No problems with spin cycle.
    Sergeant:
  • 374 Answers
Sounds like you need a new bearing.
Posted on Nov 18, 2014
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
SOURCE: Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Posted on Oct 29, 2008
meBNme
  • 334 Answers
SOURCE: GE Model wwsr3090t6aa Agitator problem
You probably have burning belt LOL.
Can you turn the agitator by hand at all?
If no, look for anything that may have gotten wedged under the agitator causing it to lock up.
If you can turn it a little. you most likely have a worn stretched belt or tensioner spring.
The only solution for that is to replace the belt or tensioner spring.
Posted on Dec 06, 2008
  • 71 Answers
SOURCE: GE washer not agitating
when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
Posted on Dec 12, 2008
ned_san_jose
  • 234 Answers
SOURCE: GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Posted on Jul 07, 2009
All the program working normal except agitator cycle
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Apr 06, 2015 | Hoover Washing Machines
Our whirlpool wtw5100vqo agitator doesn't work I already replaced the agitator dogs
Apr 03, 2015 | Whirlpool Washing Machines
Samsung washing machine model no WA80T4G everything is alright water also taking inside but wash & other options not working
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 17, 2015 | Samsung Washing Machines
Washer does nor drain
hELLO THERE:
let me explain this as best i can so please read the entire post ok?
Sometimes the most obvious answers are the first ones overlooked. If the tub isn't draining, first check the drain system. Check the drain hose to make sure it isn't kinked. Also check any lint filter that may be installed. On some Whirlpool/Kenmore models, there is also a side-check valve at the tub outlet that can get clogged.
There aren't too many things that can go wrong with a pump. The pump bearings can seize, stopping it from turning. The pump can be jammed by socks or other small items. The impeller blades can break off due to junk entering the pump; if this happens, the pump may seize up, or it may just stop pumping. The usual solution is to replace the pump.
But the symptoms of a pump failure are something else altogether. If the pump locks up, and the motor is still trying to turn it, something's gotta give. If the pump is belt-driven (as it is in many washers) the pulley driving the pump may shear off, or the belt may break. The belt may ride over the locked pulley, or the motor pulley will continue turning under the belt; this will burn the belt and possibly break it. There may even be enough tension on the belt to stop the motor from turning.
The symptoms can be confusing. For example, a common complaint about a Whirlpool belt-drive washer is that it isn't spinning, accompanied by a strong burning smell. The problem is almost always a pump that's locked up. The washer doesn't enter the spin cycle because the spin is interlocked with the drain cycle. This means that the basket won't start spinning until the water is partially drained. The burning smell comes from the rubber belt, which is riding over the motor pulley or locked pump pulley.
NOTE: If you EVER find a broken belt, check for a locked pump, transmission or other pulley before replacing the belt.
If you suspect that something is jamming the pump, drain the tub and pull the hoses off the pump. Look into the hoses and the pump and pull out whatever is jamming it. If you can't see anything jamming the pump, feel around the inside of the pump inlets and outlets with a pair of needlenose pliers. If all else fails, and you still can't find the jam, pull the pump out of the machine and check it.
Nov 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Agitator stops working after 10 seconds
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
May 05, 2009 | Hotpoint GE VWSR4150DWW WASHER
MY WFW8300SWOO front load sport washer has emptied and will not spin, door remains locked will not open, unplugged unit for 3 hours and nothing is working it acts on it own. It has no error codes on...
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
thanks and please do not forget to accept the solution
Apr 03, 2009 | Whirlpool WFW8300SW
Kenmore washer 4yrs old.Model #11024622300 Top loader
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Jul 19, 2008 | Washing Machines
Burning smell + Screeching sound but Belt is not the cause, then WHAT is?
A lot of people may be searching for help with horrible sounds and burned belts for Maytag and Admiral washers only a few years old from Home Depot etc. They used a cheap pump that has a corrugated sheetmetal ring that holds the bearings. Well as it runs the vibration and friction cause it to slip down and grind on the pulley as well as not turn easily. If you put the washer on it's back and turn the small pulley and it turns with a gritty feel or you can actually see a loose metal collar type ring thing that looks like a cookie cutte; then you have a bad pump.
There is a small access panel on the back of the washer. Three screws and two spring clips on the hoses and you're done (use big pliers on the hoses). Put the belt back on (just push motor to one side, it's not tight), then check for leaks and reinstall the cover. VOILA! You can find the pump on ebay for $25 or your local GE parts dealers for $50.
Sep 11, 2007 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
