Question about Minka Dryers
We had to take down the 56" Minka Aire Fan w/light to change size of rod and now we can't figure out the parts? We just need to see where all the parts go, especially top.
We have some of the parts confused. We just need to see where some of the parts go, especially the top. Our middle section, right at the top of the blades does not seem secure enough, that's what has us worried.
    Sergeant:
  • 374 Answers
Try this.
http://www.minkagroup.net/sites/default/files/product_manuals/F529-L-English.pdf
If this is not your model, it may still work. If not, post your model number.
Posted on Nov 18, 2014
  • 10865 Answers
SOURCE: Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Posted on Sep 07, 2009
  • 377 Answers
SOURCE: I have a minka aire
If you go to this URL:
http://www.lightingdirect.com/mediabase/specifications/MinkaAireF603Manual.pdf
you will see the instruction manual for your fan. The instructions are for an "in wall" switch for fan control. Although a little vague for me since I do not have the fan in front of me, they explain the way to reverse the direction of the fan.
I believe there is another URL that night be helpful to you as well, I will attached that URL via another comment.
If you find this solution to be helpful, I would appreciate a Thumbs Up. If you do not understand the information on the URL, please feel free to message me. Paul
Posted on Oct 07, 2010
SOURCE: Minka Aire Como F603 - Light bulb burned out
I found the Manual to the F603 in pdf format at: http://minkagroup.net/Admin/UploadFiles/F603-English.pdf It describes how to put bulbs in so it was simply a matter of reversing the instructions to get the old ones out. However, it is not that easy to get the bottom section off so one has to be careful or you will twist the whole unit instead of just the bottom part..... I think what you did was push up too hard and then turn the whole unit. Try pushing up firmly but at the same time hold some fingers (or have someone help in this) on top of the bowl above the fan blades and then twist counterclockwise an inch or two and the bottom part will release (don't let it fall). Then you have easy access to the bulbs. Good luck.
Posted on Oct 08, 2010
RyanFanMan
  • 342 Answers
SOURCE: cannot figure out how to
there is a band around the cage that you have to remove that takes some paitence but that should fix it
Posted on Jan 01, 2011
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Posted on Jan 23, 2011
How to bypass a Concept II fan receiver?
SURE you want to do this? A REPLACEMENT Receiver is just $36 bux...
Minka Aire P001021500S Receiver 6 5Uf Dl
[Brand & Part #: Minka Aire P001021500S SKU #: minp001021500s UPC #: 706411042003]
This APPEARS to be your manual:
https://www.1800lighting.com/documentation/Installation/Minka-Aire-Ceiling-Fans/F518.pdf
>>> See Figure 4 <<<
The big question IS ~ how will you switch the fan and lights after your mod?
*** DO THIS AT YOUR OWN RISK! POWER OFF FIRST ~ have a DEPENDABLE/BRIGHT flashlight ready!! ***
MARK BOTH ORANGE WIRES at "both ends" with small strips of masking tape: "1" and "2"... )so you should end up with 4 strips). #1 at the Receiver and then #1 at the fan. #2 at the Receiver and #2 at the fan.
Looking at figure 4 ~ "I" would connect WHITE to WHITE.
Then connect (two) ORANGE + BLUE + BLACK wires together... TWIST them tightly-TIGHTLY together. Now TRY a YELLOW wire nut to bond them all together... if that is not large enough use a RED wire nut.
CAREFULLY strip more insulation jacket ~ if needed... then trim to required EQUAL length.
YOU DO understand this will put your LIGHTS AND FAN into a constant ON condition? And I suspect your FAN will be at high-speed?
Anthony
Dec 20, 2017 | Dryers
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
www.fixya.com/support/t26033435-program_minkaaire_r211_remote
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
minkagroup.com/sites/default/files/product.../RC212-English.pdf
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
https://www.youtube.com/watch?v=359xzOXynxI
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 | Dryers
Change bulb on minka aire fan
Call Minka @ 1-800-307-3267
Nov 03, 2015 | Minka Aire Ceiling Fan
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Our Minka Aire ceiling fan turns off all by itself (both the fan and light)
You either need a new receiver or you need to change the dip switches in the receiver & transmitter.
Aug 27, 2013 | Minka Aire Ceiling Fan
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Jun 01, 2008 | Minka RC120 Remote Control
Dryers Logo
42 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
