Just press the Reset button to reset the hard lockout, but if it does not work even after that, it means the lockout condition of your boiler needs to be cleaned. So better contact a Registered Gas Engineer in Essex to get the work done flawlessly.
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults.
First you need to make sure your tablet is powered off.
Hold down on the Volume + button and hold down the Power button at the same time.
As soon as the tablet's screen turns on, let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
At this point you will see a screen with boot options.
Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
At this point it will be going through the wiping and resetting process.
When it's done you will see the first screen you came to when you first started the setup.
Just tap the Power button to select Reboot System Now.
You may have to call your phone company to take it in and have them do a hard reset on the phone. They should be able to back up any pictures or media files he has on the device.
All TV sets use a microprocessor for this--both the buttons on the set and the the remote end up at the same place--in most cases the buttons on the set have priority over the remote.
Only a few possible reasons for this:
The most likely and simple one is the set has a lock out feature so channels cannot be changed--owner manual or a call with the model number to (says Vizio here) would resolve that.
While on phone if no lockout exists describe problem and see if its a known issue with this model.
Its hardly likely a problem with the remote as front buttons would still function--
This if no lockout or even a hard reset exists leaves a Microprocessor problem which since not parts but circuit boards are sold--going to have to replace a board
I really think to solving this is is there a lockout or a hard reset that should cure this?
Hi, try..... it worked for me. Power Button Lockout is displayed.The
monitor's Power Button Lockout function is enabled. Press
and hold the power button for 10 seconds to unlock the power
button function.
