<!-- from fixya rte -->How do I open the copier to install toner - Office Equipment & Supplies
  • Al Clark Nov 18, 2014
    Hi Linda Veyette, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?What make and model of machine?
  • Linda Veyette
    Linda Veyette Nov 19, 2014
    Sorry - that would help. It is a Canon all in one MF4150
    New Friend:
  • 12 Answers
Which brand and model can you give more info
Posted on Nov 19, 2014
How do install toner IR 400 canon
Open machines front door,
pull down developer-units (DP),(toner cartage) handle,
remove DP fill New toner ....
simple
Mar 09, 2015 | Canon imageRUNNER 400S Copier
Tip
Konica Minolta Copier service code C0070 C-0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
on Jan 04, 2010 | Office Equipment & Supplies
How can install toner 114 for konica minolta211 copier?
Open the front door you will see the pictures how to install toner step by step. If no label of instruction,1) Open the front door 2) Pull the Old toner going you(it will swing) 3) Shake the New toner114 4) Pull out slowly the old cartridge 5) Removed SLOWLY the zeal of new toner 6) Insert it then closed .
Oct 21, 2014 | Konica Minolta Office Equipment & Supplies
Installed new toner cartridge but toner fault will not reset
if the copier was long time without toner, you need to open and close the front cover few times until it stops blinking.
If these doesn't helps, you need to vacuum and clean the toner handle mechanism, because there are toner leftovers that obstructs the new toner pass to developing assy.
Hope that helps!
Apr 29, 2011 | Ricoh Aficio 2015 Copier
C0070 machine trouble
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Minolta EP4000/5000 CS/PRO Copier
We put in new toner but it is still saying it needs toner
open the white cap on the toner bottle and instal again if it repets open the fruntdoor and close it repeatedly other wise call tech person -thanks
Dec 09, 2010 | Gestetner DSm725 Color Copier
MACHINE SHOWING THE 0070 CODE PROBLEM
If the code comes back after the cartridge is re-installed then there is either a problem with the cartridge or with the toner bottle drive.
Jun 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Toner out light
Open an close the front door on the machine a few times and it will add enough toner to extinguish the toner add light.
Feb 17, 2009 | Canon ImageRUNNER 1670F Copier
CLC 3200 COPIER
Do you have a CLC1150 or a CLC3200. If you have a 3200 you have to open the front door and go to the low toner color and unlock the lever and remove the toner cartridge and then open the new toner box and remove the orange tabs and install the new toner cart ridge and lock the lever and close the front door. You may have to wait till the copier catch's up with replenishing the toner and you are done. If you have a 1150 you have to open both front doors and on the left side of the hopper there is a black release lever, that will allow you to pull the hopper out to open the correct toner that is low. Opent the door and install the new toner bottle and remove the emptied toner bottle and push the hopper back into place and close the front doors. Good Luck
Nov 28, 2008 | Canon CLC 1150 Color Copier
k24674
