Question about Tablets & eReaders
Why can't I connect to the internet?
Every time I attempt to connect to the internet, it says Authentication failed
  • 25 Answers
Was your SSID password changed? verify your wifi settings.
Posted on Nov 18, 2014
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
My tablet does not connect to Wi-Fi, it says authentication problem, any ideas?
Authentication problem means that the WIFI router isn't accepting the security password that you are attempting to use. They are case sensitive and must be entered correctly or else the unit will refuse connection. The router may also have your MAC address blocked as this is another security option that can be entered by the router's administrator.
Jun 18, 2015 | Tablets & eReaders
Why won't my tablet connect to the internet?
Authentication errors happen when the tablet does not have the correct credentials to log onto the network. Be sure you have the correct SSID and password to join your local network. You can check this in Settings.
Apr 14, 2015 | Tablets & eReaders
How do I connect to my wifi
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
Cheers
Nov 17, 2014 | Polaroid 7" Internet Tablet Android 4.0...
When I try to connect it says authentication problem
It appears that the wi-fi you are attempting top connect with requires an authentication code. If you are connecting at home, it is the passcode for your router. if a business or pay for service system, you will need an account to connect.
Nov 08, 2014 | Tablets & eReaders
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
How to fix kindle fire 7 wi fi authentication failed
This is normally caused when the Kindle does not completely understand the authentication used or the Key used is invalid.
Step 1: Log into the Wireless router
Step 2: Verify the Key used, if the key stored in the Wireless is correct, reboot the Wireless Router
Step 3: When the Wireless Router is back online attempt to sign in again, if it fails log back into the Wireless Router
Step 4: Change the Wireless Encryption from WEP to WPA Personal and enter a passphrase
Step 5: Attempt to login to the wireless using the new passphrase
Apr 14, 2013 | Amazon Kindle Fire HD
I cant get wifi connection on my kindle hd
Step 1: Remove any old connections in the Tablet by Long Press Forget Connection
Step 2: Reboot your Wireless Router
Step 3: Attempt to connect again
Step 4: If this fails, log into the Wireless router and charge the authentication mode from whatever you have now to WPA Personal and enter a Passphrase you can remember
Step 5: Connect to your Wireless using the new Passphrase
Apr 07, 2013 | Amazon Kindle Fire HD
Internet not connecting
  • Under settings on the tablet enable the wireless radio.
  • Once enabled you should get a list of available networks, select yours.
  • Enter any password you have.
  • If you get an authentication failed message and you know your password is correct, try disabling security on your network and try again. Some tablets have a problem with security especially those running ICS.
Dec 08, 2012 | Coby Kyros MID80244G Tablet
Tablets & eReaders Logo
46 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
