if it only a week old or brand new , take it back for warranty service or warranty exchange for a new one
Personally if it failed so quick I would be basking for my money back and buying a better quality unit
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Most likely it is your drive coupling that has broke; it is a common problem. You need to remove the shell (housing) and then disconnect the pump from the motor. Also, it may be the pump that has ceased-up and will not turn (therefore the click sound as the motor shaft turns but the pump does not. If the coupling is not bad, this is best time to replace coupling (it is on the other side of the motor) and will cost $10 for the part. The pump it usually not repairable and for $30+ buy a new one. Goodluck, Macgivor
It sounds like you only have the standby 5vdc circuit working, first place to look is the main power supply module, or it can be the main circuit board.
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
