Question about Hobart CG10FI-1 - Full Size Steam Generator Combi Oven w/ 10-Pan Capac
What is the reason of code #2 fault on Hobart combi oven?
    Champion:
  • 208 Answers
Hobart will answer that for you! Typically these are water low or thermocouple temp probe fault... I'd check the resetable limit switch for the oven and boiler before I called to be safe/ should be easy to locate in the control panel...
Posted on Nov 26, 2014
I have a fault code on combi oven Rational CM61 THE FAULT CODE H20
Either you have scale buildup on the water level probe or a faulty filling valve.
Jun 27, 2017 | Combi Ovens
Hi I need a list of error codes for an Angelo Po Combi oven. Model number is FCV101EDS
F0 - No Alarm Signal
The main control board in your oven has failed to communicate with the alarm. This is most likely a fault with the control board itself, which may need replacing.
F1 - Door Not Locking
If there is an issue with the door lock in your appliance you may see this error code. Check the door lock and the wiring and connections to it to get to the cause of the fault
F2 - Door Not Unlocking
The opposite fault to the above, this fault indicates your oven door won't unlock. Once again you'll need to check the door lock mechanism and its wiring and connections. This fault could also be down to the oven thermostat as this could be giving an incorrect temperature reading, preventing the door lock from being released.
F3 - Self Test Error
Turn off your appliance, unplug it for five minutes or so and plug it back in again. Doing so should clear the F3 error code. Easy as that!. If it does not clear the problem you are likely to have a fault so see the links to our diagnosis videos below.
F4 - Temperature Sensor Fault
If you see this error code you'll need to check your temperature sensor and the wiring and connections between the sensor and the main control board. You may need to replace the sensor.
F5 - Control Board Error
This fault suggests a problem has developed with the main electronic control board in your AEG oven. It may need replacing to bring your machine back to full working order again.
F7 - Mains Supply Issue
You'll see this fault if your oven has detected a problem with the power coming into it. This could mean your appliance has been wired in incorrectly. You'll need to check the mains supply connection to your oven to get to the bottom of this error code.
F8 - Power Supply Issue to Control Board
The main control board is not receiving power as it should. Check the wiring and connections to it. If all the connections are fine, you'll possibly need to replace the control board.
F9 - Processor Auto Resetting
As with error F3, turning off and unplugging your appliance for five minutes before plugging it back should reset and fix this fault code.
Oct 24, 2016 | Combi Ovens
Amw528 error5
Microwaves have fault codes to help us determine the problem. Click the link below, it will take you to the Panasonic Combi Microwave site. Look at the manual closely. Either the fuses are blown or the microprocessor board is fried. Good Luck and be careful! Safety first! Commercial Microwave Ovens Large Microwave Commercial Kitchen Appliances...
Feb 05, 2016 | In Microwave Ovens
Bof fault code
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
http://www.dishwashers-direct.com/uploads/Operating%20instructions/Hobart/AMX%20RANGE%20OP%20MANUAL.pdf
Apr 19, 2014 | Hobart Dishwashers
Where can i go and dowload the wiring manual for the baxter gas oven
Hobart, the parent company of Baxter are very picky with releasing manuals, diagrams, etc. Your best bet is go to the link below and create a user name and see if they give you access to the manuals.
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2FPagesZ2FInstructOperManuals.aspx&reason=0&formdir=2
Nov 14, 2011 | Baxter BXA2G Stainless Steel Gas Single...
AEG Fault code E202 On opening the door of my microwave combi oven the interior light flashes accompanied by what sounds like a relay chattering and the display flashing between the normal display and...
I would suspect a bad door switch or door switch mount, or possibly a bad electrolytic capacitor on the control circuit board.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Beyond that, I could only speculate, since I don't have experience or information on AEG products.
Jan 09, 2010 | Electrolux Microwave Ovens
Hobart HEC40 208V to a 240V source
The only difference should be the elements. Consider installing a buck-boost transformer. It may be cheaper.
The Hobart part number for the 240 volt element assembly is --
# 342170-00002. Your local Hobart can get you a price.
Mar 08, 2008 | Hobart HEC501-208V Electric Single Oven
Hobart CG10FI-1 - Full Size Steam Generator Combi Oven w/ 10-Pan Capac Logo
52 people viewed this question
Top Hobart Electrical Supplies Experts
fred_therese
Trevor Turner
Bill Boyd
Are you a Hobart Electrical Supply Expert? Answer questions, earn points and help others
