Question about Lands Phones
Sound point pro se225 makes an annoying hum when on speakerphone or on the handset, is there anyway to fix?
  • 57 Answers
The only easy fix for this is hoping its a noisy mains supply or fault with the power supply. When on hands free the phone requires more power and the power supply is probably not working like it used to.
Start by disconnecting the phone line and press the handsfree button it probably will still have the same background noise. If so look to see if you can get an alternative power supply for the phone, alternatively try plugging the power supply in somewhere else away from any other cables that supply other equipment.
Power supplies over time can suffer from expanding capacitors that deteriate and cause the output to no longer be smooth or within tolerance.
If the supply is a 12v 1amp supply for example. (will be printed on the label of the bit that plugs in the wall) any power supply will work with the same specs you just need one with the same connector.
The most likely problem will be with the built in amplifier inside the phone that drives the speaker. This is not a simple repair and will require electronics knowledge, but if you feel your up for it and its out of warranty open it up and look at the pcb near where the speaker is connected any capacitors around that area that don't have a perfectly level top may need replacing.
Posted on Nov 19, 2014
3 Suggested Answers
SOURCE: Panasonic Speakerphone base station makes noise when handsets use
Cut the wire to the speaker in the base unit. Problem solved.
I have a Panasonic KX-TG6074b phone as well, and it does the same thing. In addition I can not understand the digital voice that announces who is calling. Therefore I came up with a very simple solution to buying a new phone, because the rest works great. I cut the wire to the speaker. The only other solution in buy a phone from a different manufacturer, because Panasonic's quality stinks.
Posted on Mar 01, 2010
  • 1116 Answers
SOURCE: I have a polycom soundpoint
There may be two different conditions potentially causing this issue.
If type 1, a.k.a. "normal" Caller ID is turned on through the local phone service, the name and phone number of the person calling will be displayed on the SoundPoint Pro's LCD when the phone rings; or, if you are on the phone and a call comes in on another line which is not in use. For the SoundPoint Pro phones to understand the signal from the carrier, the Caller ID signal should be on the second ring. If your local phone service sends the Caller ID information on the first ring the SoundPoint Pro may not receive it and will not display the information.
Check with your phone company to verify on which ring their signal is being sent.
This is the second.
The SoundPoint Pro phones may display no caller ID or display all Zeros for the caller ID or only display one number all of the time. These symptoms are all caused by the same issue, the inability of the software to overwrite the call history which has become full. This does not occur in all phones and replacing the phone does not always resolve the issue. Work Around: SoundPoint Pro SE-220 and SE-225 have a feature to clear call history. Incoming or outgoing call history can be cleared by pressing Select then arrowing down to INCOMING CALLS or OUTGOING CALLS then press Select > Clear Call History. Clearing the Call History should restore the normal function of the Caller ID Display.
Posted on Aug 09, 2011
HOW TO TURN Silent,Mode off
Note* in some rare cases, the phone itself can become defective or damaged to a point to where the volume reflects loud ringing but doesn't make any sound. In that case customer service should be available by calling uniden directly.
menu , vol up down
advanced , press enter
silenmode, volume up till display" off"
Mar 23, 2016 | Uniden D1680-4 Cordless Phone - Dect 1 x...
Why is light staying on and its making annoying humming sound?
The door switches are either faulty or not being depress when the door is closed, this usually means that the door and the cabinet are out of alignment
Dec 23, 2015 | In Microwave Ovens
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
My phone is stuck on speakerphone. When I pick up...
There are two things to check that you can fix. First, try replacing the handset (curly) cord. A broken wire in the cord can make this happen. If that's not it, watch the hookswitch. That's the plunger that goes down when you put the handset in the cradle, and pops back up when you lift the handset. If it's stuck down, you will only get speaker and no sound in/out of the handset.
May 21, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Polycom SE225: my verizon line provide caller id does not displa
Due to the age of the SoundPoint Pro, it some of its features are not compatible with newer phonesystems, such as CableVision. There are no software updates for the SoundPoint Pro, and as long as the Caller ID is enabled there are no other settings or adjustments that can be made to workaround these kind of problems unfortunately. I recommend contacting your service provider to see what kind of caller ID signaling they are using; most likely they will be using a newer digital system, or MDMF which is not backwards compatible with SDMF or earlier CID receivers.
Dec 05, 2009 | Polycom SoundPoint IP 501 IP Phone
Compressor makes a funny humming noise and frigerator gets warm , if you tap the compressor it works fine for awhile, but after awhile I get the annoying humming sound again and the temp in the...
your loosing your relay or overload,,, tapping works hey...... like and old chevy starter
anyway
look at the compressor you will see the parts im tlking about
relay and overload
pull these off and ohm them out
sounds like thay are going bad
very easy reapir go to
www.appliancepartspros.com
jujst type in your model numnber
and seacrch the compressore=
compartment
order and replace you should be fine
Oct 24, 2009 | Refrigerators
Loud annoying sound when driving over 35 mph
Check the fluid level and make sure. If the fluid level is not the problem, I would have someone do a complete check on the front end.
Jun 01, 2009 | 2003 Toyota Corolla
Mar 13, 2009 | Lands Phones
MA355 Cordless Phone Makes Noise when IN CHARGER?
yes this happens to me also. I haven't tried anything to fix it but it is darn annoying.
Apr 26, 2008 | Uniden Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
