Question about Drills
I recently bought a Hilti SF 151 A battery drill. The chuck has had it and i was Wondering if anyone knew where to buy a new 1 as i cant fund 1 anywhere. Cheers in advance. Paul
  • 3,382 Answers
Hilti has the parts, contact your local rep.
Posted on Nov 19, 2014
2 Suggested Answers
  • 61 Answers
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
Posted on Jun 06, 2010
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
From where can i buy a switch for my hilti sf 121a
Under Hilti, the SF 121 is the battey part number. I would need the tool's part number to know which switch you need. On the bad side, I haven't been able to find a secondary market for Hilti parts, you usually have to buy from them. Hilti's number is (866) 445-8827 if you would like to call them and order the part.
Aug 23, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
How do i replace the jacob chuck on a hilti hammer drill?
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Jun 28, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Triger
call 1-800-879-8000 and they will be able to help you with this problem
May 23, 2009 | Hilti Cordless Hammer Drill Sfh 151 A...
I cant seem to locate a Hilti TE5A battery charger
I would call Hilti direct at 1-800-879-8000 and speak with one of their customer service reps and they should be able to help. If not let me know and I will contact my local sales rep and see what I can do for you.
May 11, 2009 | Hilti Cordless Hammer Drill Sfh 151 A...
Hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Mar 14, 2009 | Drills
Drills Logo
101 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
