Question about Water Heaters
Why is my envirotemp residential hot water heater creating black soot?
  • Water Heaters Master
  • 3,368 Answers
Because the burner is not adjusted correctly, you are waisting fuel.
Posted on Nov 19, 2014
SOURCE: Hot water gets cold after a couple of minutes
hi do you have 3/4 inch cas line running to it? if you only have 1/2 inch it is too small and running out of gas and shutting down. ed
Posted on Mar 03, 2010
senor8
  • 73 Answers
SOURCE: My Noritz N-084M-NG Residential/Commercial Indoor/...
That unit has two flow sensors. It needs to register flow through both sensors in order for it to fire. If one of the flow sensors is stuck or if there is scale blocking flow through the heat exchanger, it will not fire. I'd recommend contacting a servicer to clean the unit.
Posted on Jul 30, 2010
motor1258
  • 6674 Answers
SOURCE: Hot water tap creates an
Like a buzzing noise? Check valve where water lines connect at back will make a buzzing noise, if you only hear it when running hot water and not when running cold. Remove and replace it after shutting water off, and draining tank down. Be sure to shut off any hydro to electric element prior to draining.You can buy a replacement check valve, or just put a short 1/2" pipe nipple in there instead and reconnect your line, and refill it. noise should be gone .
Posted on Jun 11, 2011
SOURCE: To light the pilot on my OS Smith water heater, I
Thank you for providing clear description of product:
Your water heater has intellivent gas control thermostat.
There are always problems with water heaters. It is a huge field.
1) Open following link for AO Smith service manuals.
I do not see service manual specifically for the GP series.
http://www.hotwater.com/resources/product-literature/service-handbooks/
2) Open following link to identify gas valve and download typical service manual:
Some AO smith power vent models have intellivent gas valve, and some have smart valve gas vent. Older models might have knob-type gas valve.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
3) More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Posted on Sep 24, 2011
  • 5089 Answers
SOURCE: I have a PowerVent residential Gas Water Heater the blower runs continuously and the water is not hot enough
Copy following link for troubleshoot resources, including troubleshoot by type of gas control valve.
Brand and model number of unit is located on label side of tank.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Posted on Aug 06, 2012
How to change a envirotemp gas water heater into a.electric water heater
Dear Buffie,
You cannot change a gas water heater into an electric water heater, nor can you change them the other way around.
They are manufactured differently.
If, however, you are getting rid of the gas one and want to know how to hook up a electric water heater in it's place, please ask the question that way.
God bless your efforts.
May 09, 2016 | Water Water Heaters
Envirotemp hot water heater went out I can't get it relit
If it is a gas water heater put new batteries in it. They are usually D size.
Apr 24, 2016 | Water Water Heaters
Hot water heater lokced out with error codutfor ignition failure.
get some professional help, you are messing with disaster.
Apr 19, 2016 | Water Water Heaters
Why does my pilot light keep going out when heating is on ?
Water heater and house heater are sharing the same vent?
Then vent is bad, and heater is pushing combustion by-product down into the water heater and blowing out pilot.
Call technician immediately to avoid CO poisoning.
Look for black soot on top of water heater... test the vent:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
Read about Carbon Monoxide poisoning: symptoms and first aid
http://waterheatertimer.org/Is-natural-gas-clean-burning.html
Gene
Oct 08, 2014 | Water Heaters
Is a 80 gallon hot water heater legal for a 7 apt. building?
You probably need commercial 150gallon gas water heater.
Or three 80 gallon tanks, depending on number of people.
80 gallon residential gas heater is rated for low-demand 6-8 person household.
80 gallon residential electric is rated for low-demand 5 person household
80 gallon is not correct for 14-28 people in 7 apartments
http://waterheatertimer.org/Whatsize2.html
http://waterheatertimer.org/Two-water-heaters.html
Call local plumber, or local code department.
Apr 10, 2013 | Water Heaters
Is the lower element suppose to have two legs of 120 to it? Or do i need to move a wire up top to make it 240? as it is on top element.
You have water heater with two elements.
Two-element water heaters are 240Volts.
1) Lets talk about what makes a 240Volt circuit
See basic water heater circuit:
http://waterheatertimer.org/B220C.html
Open link, and illustration at top of page is your water heater circuit
Notice that two insulated wires come from the circuit breaker and go to the water heater.
These two wires are 120volt each. When these two 120Volt wires combine, they create 240Volts
These are called hot wires because they come from the hot busbars.
There is also a bare copper wire that comes from neutral busbar.
The bare copper wire is a safeguard, and is not necessary for the 240V circuit to work.
Inside each circuit breaker box is 1 neutral busbar, and 2 hot busbars.
Open image below, and it shows typical residential breaker box
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-420.jpg
In a residential home, each circuit takes two wires to complete the circuit.
For 120Volt circuit, you need 1 neutral wire and 1 hot wire to complete the circuit. These are usually a black and white wire. The bare copper wire is a safeguard.
For 240Volt circuit, you need 2 hot wires to complete the circuit, and each hot wire comes off a different busbar. These can be a black and white wire, and sometimes a black and red wire. The bare copper wire is a safeguard.
With a 240Volt water heater the two hot wires connect to the black and red wires located on top of water heater.
2) Let's talk about wiring inside a water heater.
http://waterheatertimer.org/images/WH-w-combined-530.jpg
Open image on link above, and it shows your 240volt water heater wiring.
The 2 hot wires from breaker box connect to the red and black wires on top of heater.
Inside each water heater, the wires are color-coded and will appear the same, or nearly the same, as shown on link above.
As long as your wiring appears like the image, and the hot wires from breaker box connect correctly, and the circuit breaker is working fine, then your water heater will work.
Add a comment any time.
3) More electric water heater links about water heaters, thermostats and tank wiring:
http://waterheatertimer.org/How-electric-water-heater-works.html
http://waterheatertimer.org/How-water-heater-thermostat-works.html
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Dec 28, 2010 | RELIANCE ELECTRIC WATER HEATER
Low pressure at hot water tap
Most tankless heaters will normally restrict the hot water output in order to maintain a stable outlet temperature; however, this should only be noticed if you have several hot water fixtures open. If you are only seeing the problem when running a single fixture, then the problem is probably one of these items:
1) clogged aerator on your fixture - easily fixed by removing and cleaning the aerator with a pair of vice grips
2) clogged inlet filter for your tankless - the inlet filter is located on the incoming cold water connection. It has a black cylindrical cap. To remove it, make sure to first turn off your water to the heater and then unscrew the cap to remove the filter. Instructions can also be found in your owner's guide.
Oct 12, 2010 | Noritz Residential Heaters Tankless Water...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
Sep 18, 2010 | Whirlpool Water Heaters
Error code 14 shows on the remote for a noritz tankless lpg water heater. what does it mean?
This means the thermal fuse has broken and needs replacement. The thermal fuse is a white cord which wraps around the heat exchanger. It typically breaks if the unit is excessively dirty and sooted. Before the fuse is replaced you should make sure the unit is cleaned with compressed air and descaled.
Dec 10, 2009 | Noritz 6.3 Gallon Residential Tankless...
Water Heaters Logo
63 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
