Question about Ignition System for Ford Escort
02 focus suddenly died starter does not turn now have power at dash
    Habit-Forming:
    New Friend:
  • 160 Answers
Probably starter solenoid. Whack starter motor a couple times with a block of wood, then once it starts have it checked out and replace if needed. Last thing you need is a flaky starter with winter weather.
Posted on Nov 18, 2014
My 02 focus suddenly died now wont turn starter have power and dash lights
Check the starter relay to see if it is energizing, if so check the starter motor.
Nov 18, 2014 | Ignition System for Ford Focus
Clio engine noiseengine suddenly died
Sounds like you forze up the engine.
Mar 21, 2014 | 2002 Renault Clio
My 95 sierra dies and won't start. no lights on dash then suddenly lights come on and truck will start. please help.
first check the connections at the battery. make sure there is no corrosion between the cable end and the battery.
When you say it wont start can you hear the starter cranking the engine over or is the vehicle completely dead?
If its completely dead I would check for power to the ignition switch. if there is power than I would check for power out of the switch. If there is no power than possible the ignition switch is failing.
I might be able to get you some wiring info if needed. just let me know.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 02, 2013 | 1995 GMC Sierra
I just bought a 1994 bmw 525i . Suddenly it wont turn over. acts like dead battery but I have power.
When you say you have power, do you mean the dash lights come on?
The power requirements of the starter motor are a lot higher than that of the dash lights or even the headlights and accessories.
Turn the headlights on and try to start the engine, if the headlights go really dim or right out then your battery doesn't have the capacity that the starter needs to turn the engine over and you need to replace it.
Aug 21, 2010 | BMW 525 Cars & Trucks
02 rendezvous no crank no start power in dash
Battery may be good but the termanals may need to be clean of corrosion. This means scraping the inside of the cable ends as well as cleaning the posts. Also remove the cable ends that connect to thecables and clean the cable copper and inside of ends. Just because you have dash lights does not mean enough juice is there for the starting. Let me know how it turns out. I hope this helps< The Raz
Apr 16, 2010 | 2002 Buick Rendezvous
02 Chevy Cavalier - Fast Clicking Noise When I Turn Key
your battery isnt holding enough charge to crank the starter.thats what the clicking is. try charging you battery for a good 8-10 hours, if it still does the same thing you'll need a new battery.
Nov 02, 2009 | Chevrolet Cavalier Cars & Trucks
Toyota lucida that was running fine then suddenly stopped,lights came up on dash then the engine died,tried to restart but the starter motor just clicked.i have changed the starter but it still clicks and...
If you have a known good starter on it and all the wiring to starter and relay is good, you may have a locked up (siezed) engine from lack of oil pressure or runnung hot. I would try turning engine by hand (put a socket and ratchet on the balancer bolt) and try turning it, if it doesn't turn then it is locked up.
Oct 15, 2009 | 1992 Toyota Previa
Died suddenly and won't start
sounds like a instrument cluster fault
Feb 27, 2009 | 2001 Ford Focus
Starter motor dead...I think
If Its A Manual Can It Be Kick Started? If The Dash Lights Are coming On And Dont Dim When Fully Charged Its Probably The Starter Sticking . If You Hook It Up To Someone For A Jump Start Does It Start? If No Its Your Starter.
Next Time It Wont Start Try Hitting The Starter With A Hammer.
If That Works Its The Starter.
Lots Of Things To Narrow It Down And Be %100 Sure Its The Starter
Jan 12, 2009 | 1992 Toyota Corolla
Ignition System for Ford Escort Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
