Question about Ignition System for Ford Focus
My 02 focus suddenly died now wont turn starter have power and dash lights
  • Ford Master
  • 3,368 Answers
Check the starter relay to see if it is energizing, if so check the starter motor.
Posted on Nov 19, 2014
02 focus suddenly died starter does not turn now have power at dash
Probably starter solenoid. Whack starter motor a couple times with a block of wood, then once it starts have it checked out and replace if needed. Last thing you need is a flaky starter with winter weather.
Nov 18, 2014 | Ignition System for Ford Escort
Clio engine noiseengine suddenly died
Sounds like you forze up the engine.
Mar 21, 2014 | 2002 Renault Clio
My 95 sierra dies and won't start. no lights on dash then suddenly lights come on and truck will start. please help.
first check the connections at the battery. make sure there is no corrosion between the cable end and the battery.
When you say it wont start can you hear the starter cranking the engine over or is the vehicle completely dead?
If its completely dead I would check for power to the ignition switch. if there is power than I would check for power out of the switch. If there is no power than possible the ignition switch is failing.
I might be able to get you some wiring info if needed. just let me know.
Apr 02, 2013 | 1995 GMC Sierra
2006 chevy 3500 dually 6.0L dies as soon as the starter catches. it acts like its going to start right up but dies suddenly. the dash lights or dome light wont come on nor when switches are activated. ...
if thats a diesel inspec fuel injection pump for issues and also glow plugs--underhood chec for bad wiring--if gas engine then a tuneup cud be in order-new plug wires or coil/ign module--fuel pump may be failin
Nov 21, 2010 | 2006 Chevrolet Silverado 3500
I just bought a 1994 bmw 525i . Suddenly it wont turn over. acts like dead battery but I have power.
When you say you have power, do you mean the dash lights come on?
The power requirements of the starter motor are a lot higher than that of the dash lights or even the headlights and accessories.
Turn the headlights on and try to start the engine, if the headlights go really dim or right out then your battery doesn't have the capacity that the starter needs to turn the engine over and you need to replace it.
Aug 21, 2010 | BMW 525 Cars & Trucks
02 Chevy Cavalier - Fast Clicking Noise When I Turn Key
your battery isnt holding enough charge to crank the starter.thats what the clicking is. try charging you battery for a good 8-10 hours, if it still does the same thing you'll need a new battery.
Nov 02, 2009 | Chevrolet Cavalier Cars & Trucks
Toyota lucida that was running fine then suddenly stopped,lights came up on dash then the engine died,tried to restart but the starter motor just clicked.i have changed the starter but it still clicks and...
If you have a known good starter on it and all the wiring to starter and relay is good, you may have a locked up (siezed) engine from lack of oil pressure or runnung hot. I would try turning engine by hand (put a socket and ratchet on the balancer bolt) and try turning it, if it doesn't turn then it is locked up.
Oct 15, 2009 | 1992 Toyota Previa
Key turns but wont start
starter relay maybe try it out
Aug 16, 2009 | 2002 Ford SVT Focus
Focus c-max non starter
if the starter is not turning the engine, then it is either a weak or jammed starter, or a siezed engine.....tap the starter with a hammer ( lightly )...while someone tries to start the engine...if nothing happens, then its the engine.......try a spanner on the pully of the flywheel, and turn manualy by hand, if it wont turn, then the engine has siezed
Jul 28, 2009 | 2000 Ford Focus
Starter motor dead...I think
If Its A Manual Can It Be Kick Started? If The Dash Lights Are coming On And Dont Dim When Fully Charged Its Probably The Starter Sticking . If You Hook It Up To Someone For A Jump Start Does It Start? If No Its Your Starter.
Next Time It Wont Start Try Hitting The Starter With A Hammer.
If That Works Its The Starter.
Lots Of Things To Narrow It Down And Be %100 Sure Its The Starter
Jan 12, 2009 | 1992 Toyota Corolla
Ignition System for Ford Focus Logo
47 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
