Question about Frigidaire Refrigerators
My frigidair (refrigerator only) - there is no freezer - is at 10 degrees even at the lowest setting
This is a refrigerator only machine. everything keeps freezing even at the lowest setting of 1. have a thermometer in there which is showing 10 degrees. is about 2.5 years old.
  • rani fogel
    rani fogel Nov 18, 2014
    where is the thermostat located?
    Habit-Forming:
    New Friend:
  • 155 Answers
Check to make sure fridge thermostat is not covered or iced over
Posted on Nov 18, 2014
Testimonial: "Where is the thermostat located?"
SOURCE: refrigerator side freezes even on lowest setting?
It may be a problem with the damper panels that are situated between the freezer and the refrigerator. Most people note a problem when the damper doors stop opening and food becomes warm. In your case the doors may be not closing properly.
This may be mechanical, the damper louvers assembly is broken, or it may be electrical, the relay switch and motor assembly that operates the damper is not operating properly.
In side by sides the damper is usually in the upper side rear of the refigerator. If you can peer into it, you may be able to see light from the freezer (freezer door open) which would confirm the louvers are open.
Quick fix? duct tape a portion of the opening. It will restrict cold air flow. Costs little, and if you are not particular will work. Other fix. Call a repair man and be prepared to pay about 200 for the parts and labor.
Aloha
Posted on Sep 18, 2009
  • 35 Answers
SOURCE: freezer and refrigerator run about 8 to 10 degrees
check freezer coil for ice, then defrost timer and then fan and switch fan
Posted on Jan 02, 2010
mnwarfield10
  • 452 Answers
SOURCE: the refrigerator is freezing even at lowest
yes chang stat.. also sensors if it has any ..
Posted on Jan 04, 2010
SOURCE: Refrigerator is no longer keeping the food cold
change the compressor of your refrigerator
Posted on Apr 25, 2010
machinetech7
  • 1344 Answers
SOURCE: Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
Posted on May 17, 2012
Testimonial: "thinks alot, after 24hrs it staying at 39f so its working now i don't know why but she all fixed the only thing i did was turn it off for a min and turn it back on. "
Frigidaire side by side Freezer only freezing top shelves, warm at the bottom
Its defrost issue.
Defrost cycle is not taking place on time or its not working at all.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Frigidaire Refrigerators
Frc150ff fridge is too cold
You know that the lowest setting is the coldest .
Set it to 35 refrigerator, 6 degree freezer and see what haopen
May 27, 2017 | Frigidaire FRC150FFS
When set at the coldest setting the refrigerator will not go colder than 48 degrees. The freezer is holding at 10 degrees.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 21, 2011 | Frigidaire Refrigerators
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
May 24, 2010 | Whirlpool GS6NBEXR Side by Side...
Freezer used as a frige?
it may be possible. Turn the temperature on the lowest setting and see what happens. If it still freezes everything up then it is not posible. If it doesn't freeze everything , then check the temperature with any temp probe. It should run at somewhere between 36 and 38 degrees. This is the normal cool setting on a refrigerator.
Nov 07, 2009 | Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Refrigerators Logo
76 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
