Question about Sceptre X32BV-Naga 32 in. LCD TV
How do I take parental control off when I don't know passcode?
Tried turning it off through the settings with remote but it asks for a passcode, which I do not have.
  • Sceptre Master
  • 3,368 Answers
That is why there is a a passcode it prevents tampering. When you set a passcode it is your responsibility to either remember it or have it retreavable. Contact the manufacturer.
Posted on Nov 19, 2014
How do u get parental passcode
Try a reset
To restore the TV to its factory default settings:
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight System
and press OK. The SYSTEM menu is displayed.
3. Highlight Reset & Admin and press OK. The RESET & ADMIN
menu is displayed.
4. Highlight Reset TV to Factory Defaults and press OK.
5. If you have changed the default parental control PIN, enter it
now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults."
6. Highlight Reset and press OK.
7. Wait for the TV to turn off. The TV will turn back on shortly.
If you have not set a PIN, enter the
default, 0000
Feb 14, 2016 | Vizio E-Series E470I-A0 47" LED TV...
How do I turn the parental control off when I do not have the passcode? It was accidentally turned on while programing TV for a new cable box.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Nov 18, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
How do i disable the child lock
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
Sep 18, 2012 | Jensen TS2750J TV
A white screen just popped up & says to set a parental code but none of the buttons on the remote work... Can't see any picture just hear it..
Did the remote function before?
Not knowing brand and MODEL number hard to advise you other than turn off and unplug set for a minute and then turn back on.
If parental code has been entered you must enter it to use set---in this case also make sure if remote for several things you have it engaged for TV and not SAT or DVD etc.
I am here to help most of the day.
Mar 14, 2012 | Samsung Televison & Video
My xbox 360 has a parental rating passcode I don't
Call 1-800-4my-xbox. Explain your situation to the CS representative. they will ask you for a serial number, and they will generate a unique passcode with which you can unlock the xbox
Mar 01, 2012 | Microsoft Video Game Consoles & Games
We have parental controls on a couple programs and there are no children in this house. Don't know how they got on there- how do we remove those controls. We are in our 70's.
Try to follow this instruction:
1. Press the menu button in your remote control. 2. Press number 4 to open the v-chip parental control 3.Press and hold the volume down and channel up buttons for 5 seconds if the passcode appears. This will reset the passcode 0000 then enter this to access the parental control. Good day and best regards.
Sep 13, 2011 | RCA Televison & Video
Hello , i bought a used nintendo Wii system but i cant unlock the parental control, how can i do to change the password or parental control to be able to connect to enternet?
When asking to unlock parental controls, it should ask for a pin. Since you don't know the pin it will ask for a security question. Once again, you probably don't know the security question so ultimately, you need to follow these instructions http://www.nintendo.com/consumer/systems/wii/en_na/settingsParentalControls_reset.jsp
May 10, 2011 | Nintendo Wii Console
I'm trying to play a dvd but it says that parental controls have been set. I know the passcode is 8888 but when I type that in on my remote (universal, not original) it doesn't even recognize that I've...
Sorry u have to buy an original remote for this.The universal remote,will not be response by the tv for tthis function.Try website like Remotes.com to buy an exact to the original remote.
Oct 21, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
I turned on tv and it had the parental lock on. I
When it asks you your code press 9 and QV at the same time . This only works with the mitsubishi remote.
Nov 14, 2009 | Mitsubishi WS-48313 48" Rear Projection...
Can't get the child lock off
You can use theV-Chip Parent Lock to
Block or Allow programs based on the
ratings sent by the broadcast stations.
The default setting is to allow all programs.
You can block programs by the
type of program and by the categories
you want blocked. Or you can block all
programs during a specific time period.
To use the V-Chip Parent lock, you will:
• Enter a passcode
• Select theV-chip ratings and categories to block
• Select theV-chip hours to lock and unlock for television programs
• Select lock by time
Enter a Passcode
MENU
I. Press _ to display the Main Menu.
2. PressAorV to select V-Chip Parent Lock.
PressE_ R,
3. Using the number keys, enter four numbers. To
delete a character and move back one space, press
CANCEL ENTER
. Press _ to set the passcode and go to
theV-chip ratings menu.
MENU
4. To exit without entering a passcode, press _ to
HOME
go to the previous menu or _ to return to
television viewing.
IMPORTANT
If you forget your four-digit passcode, please
see Appendix 3 : Procedure for Bypassing the
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
MENU
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
MENU HOME
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
IMPORTANT
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
65
Nov 24, 2008 | Mitsubishi VS-55707 TV
Sceptre X32BV-Naga 32 in. LCD TV Logo
56 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
