Question about Crafts & Hobbies
What should I do to fix a room door slides closing after I opened?
My bedroom door recently is slow closed after I opened. How to fix it?
  • 10,263 Answers
Tighten the top hinge screws. If they are strupped replace them with a longer screw. Long enough to get into new wood behind the door jam. 2 inches or longer.
Posted on Nov 19, 2014
What are current resale prices in Prestige ferns residency resale?
This question should be directed to a local real estate agency.
Jan 05, 2016 | Computers & Internet
2012 dodge grand caravan side door won't stay closed
Dodge grand caravan door won't latch easy fix - YouTube
? 1:04
www.youtube.com/watch?v=MxcvPkCd70M
Dec 12, 2013 - Uploaded by Jason Sikkema
2003 passenger sliding door won't close, this maybe the problem. ... Out-of-Synch Liftgate Latch DIY Fix - 2012 Dodge Grand Caravan ...
2011 Dodge Grand Caravan passenger sliding doors will ...
? 0:16
www.youtube.com/watch?v=tJeuH9DhYG0
Nov 5, 2013 - Uploaded by 3fourjay
2011 Dodge Grand Caravan passenger sliding doors will randomly shut ... The fob would cause it to close at random positions during opening. ... be widespread and Chrysler won't do anything unless it becomes a public issue for them. ... Out-of-Synch Liftgate Latch DIY Fix - 2012 Dodge Grand Caravan ...
Oct 19, 2015 | Dodge 2012 Grand Caravan Crew
2004 chevrolet van
Get a light and look to the back of the door some time kids loose the toys in there.If that doseing fixs it grease the door track.First clean it off with brake cleaner let air dry then grease the door track and roller on the door close slow and check the lock.
Jun 25, 2013 | Cars & Trucks
Repair Van sliding door runner
If the Pontiac Trans Sport Van door is in the process of closing or opening (via motor), and the vehicle's ignition is engaged prior to the door fully closing or opening, the motor immediately stops. At this point, the only recourse is to manually close the door, as none of the power switches/handles respond again until the door has been manually closed. ----------------------------------------------------------------------------------
Car cable & OBD Connector
Dec 12, 2012 | Mitsubishi Cars & Trucks
I locked my bedroom door with my keys in the room
Look closely at the door knob and you will see a very small hole in the middle of the door knob. Use a piece of stiff metal such as a heavy paper clip straightened out and push it into that hole. that will unlock the door to your bedroom if you have a normal bedroom door lock.
Mar 25, 2011 | Garden
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
Passenger sliding door motor won't close door all the way.
I just fixed my 2005 T&C sliding door. The wire in the plastic rolling chain is broken when resides right under the step pad. It took me 30 minutes to fix.
Go to this link.
http://wiki.answers.com/Q/How_do_you_replace_the_power_sliding_door_wiring_harness_on_a_2005_Town_and_Country_chrysler
May 27, 2009 | 2005 Chrysler Town & Country
Tran A/c installed last summer
It's the ducting that causes the problem. But if the old unit wasn't as bad, did they install a smaller unit to save on money? It is possible, some companies do this to make more money. Sad but it is true. A return added to the room would help but if they can run a return, then they can add another duct or reduct the room as well. Sounds like someone is trying to sell you a story without fixing the issue. Tell them that they don't need to add an extra run, tell them to change the size! Also, make sure that if the run is longer than 25 feet, the ducting has to be stepped down in size to increase valocity to the vent. For example, you have a 10" duct running for 25' and then you step down to 8" the rest of the way unless that run is more than 25'. Hope this info helps!
Apr 02, 2009 | Heating & Cooling
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
Crafts & Hobbies Logo
139 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
