Question about Refrigerators
Light bulbs come on in fridge but no power to controls inside. any ideas? worked fine until it stopped.
Replaced capacitor on circuit board
  • 3,289 Answers
It sounds like you may failed to reconnect all / improperly connected one of the plug-in connectors after the repairs were made. You may have also dislodged one of the connectors during reassembly. Go back and double check the connectors - and make sure that you observed polarity when you replaced the capacitor. Most are clearly marked and reversing it is usually a "go / no go" deal as opposed to "close enough".
Posted on Nov 18, 2014
  • 262 Answers
SOURCE: Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Posted on Jan 01, 2008
  • 32 Answers
SOURCE: bulbs and bottom pcb blew, replaced but still not working
the start and run capacitors of the compressor can go short circuit and cause a big spike that can blow the bulbs, trip fuse etc. Inspect the capacitors for splits etc, you may well find that the start cap has blown and so there will not be enough current to get the compressor running.
Posted on Mar 19, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Control pad flashing temp and all lights continuously and ice door continually cycles open and closed
With the problems it is presenting, I would say it's very likely.
However it may take a bit of detective work to find which board is defective.
Check a part suppliers link Here for price comparison so you have some ideas.
Posted on Jun 26, 2008
SOURCE: Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
Posted on Jul 22, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
I have power going into my fridge freezer but the lights inside the fridge are not coming on and the compressor is not running and the items in the freezer are thawing out. Is there a trip switch?
sounds like possible inline fuse or electronic board is fried ,kif power to unit will have to check for power at electronic {control} board
Jun 09, 2016 | Refrigerators
I've shorted out my oven after attemtping to change the light bulb.
most ovens will not operate until you set the clock - doesnt matter what you set it to as long as it isnt 00:00
Nov 30, 2013 | Dacor Preference RSD30 Gas Kitchen Range
Magnavox 50ML8105D/17. We moved and the tv worked fine and now nothing. Just 2 red lights. Temp and Bulb. I replaced the bulb about 6 months ago. all I did was move.I carried it myself. I have checked and...
My magnavox died due to cheap capacitors on power supply board, a common problem for magnavox tv's from wot i found on net!
I replaced a 2200uf 10v electrolytic capacitor and it works now:)
My tv would take a few atempts to turn on and finally would not turn on,light stayed red!
i recommend visually checking for bulging or blown capacitors on power board, if it all looks good, try warming the board with a hair dryer, this might be just enough to get it to fire up, so at least u know the prob is in that area.
I looked for a 2200uf capacitor near the low voltage output from board n replaced it, got lucky first one, I was expecting to replace all the low voltage electrolytic capacitors.
Justin
Feb 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Fridge and freezer stopped working.Power still on (light on in fridge). Digital control for fridge and freezer shows straight line no numbers. Any suggestions?
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
Jun 05, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Fridge lights are buzzing and flickering
You need to replace the electrical control board. It's an easy fix. About $75 for the part. No electrical work necessary. Just unclipping and re-clipping wires into their ports. You do not need a repairman to do this! (I'm a 33 yr. old female, so please forgive my lack of technical terms in the post) I ordered one from AppliancePartsPros.com. It came in two days.
1. Pull out and UNPLUG the fridge.
2. Take out the screws that hold the bottom back panel on
(The electrical contol panel is located inside a white box attached to the lower left corner. )
3. Remove the screws that hold the box in place
5. Remove the bunch of wires out of the clip on the side of the box and pull the box out. Open it by releasing the clips on either side.
6. Disconnect the three sections of wires that plug into the board
7. Remove old board out of the housing
8. Insert new board,
9. Reverse above steps to complete installation.
Note: What triggers the buzzing sound is the door being opened. If you want to stop the sound and prevent the electrical current from going to the fried board until your new one comes, put a piece of tape tightly over the switch that pops out when the door is opened (located inside the unit near the door hinge).
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge prolems Electrolux ERE 3500
Disconnect the power cord (or switched power off) and wait an hour or two until compressor has cooled. When you now switch the power on, the clicking is heard only once and compressor starts (weak noice and vibration noticed). When compressor gets warmed, the compressor will stop and clicking starts again (clicking comes from electric circuits when compressor is switched off and on repeatedly, but it will not start because it has stucked - this is typical fault in old compressors said maintenance expert to me). Buy a new fridge.
Mar 29, 2008 | Refrigerators
Bulbs and bottom pcb blew, replaced but still not working
Mar 18, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
