Question about Kodak Carousel 650h Slide Projector Instruction Manual On Dvd
I can't get the bulb to work.
New bulb no light.
Turn signal not working, dash signal lite staying on
If bulb or socket melted then replace socket. May be OEM part not sure. Easy fix just be sure to use seal type crimp connectors or you will be working on this a year later.
Jul 20, 2014 | 1994 Jeep Wrangler
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
Beam one side replace hight lite works but one low do not
you need a new light bulb. there are two different bulbs for high and low beam or 2 filements in one bulb. ether way you need a new light bulb
Mar 13, 2013 | Cars & Trucks
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
Model number ffhs2313lp3 light burnt out got a new one wont work
if you new light still didn't work . so what's the problem ? maybe the light was in good condition . did you check you circuit board ?
home light bulbs
May 31, 2012 | Frigidaire Refrigerators
Sylvania ceiling lights in my Kitchen Not working i have new Light Bulbs that i have Got to replace it have put the New Ones in Still No light I have 5 Lights Not working Changed All 5 Now only 4 are...
Are the lights wired black to black, and white to white?
If lights are on timer or dimmer, make sure timer-dimmer are rated for type of bulb, and wattage
Some timer must have minimum wattage.
Use non-contact voltage tester to see if lights are getting power when switch is ON.
Check if wire nuts are tight.
Fluorescent? Look at ballast and see if black ooze is coming out to indicate that ballast is bad.
Check that bulbs are correctly held in place.
If one bulb is bad, others might no work. Replace bulb when it starts getting dark on the ends.
Incandescent? Check that light bulbs are good
Install new switch.
Check white neutral wire located in back of switch box and covered with wire nut.
Click breaker all the way off and then back on.
Nov 08, 2011 | Home
My tail lights are not working on my 2000 jetta the front lights work the break lights work and the blinkers work all inside lights work just fine
you need new bulbs in tail lights one bulb in each side has two elements one works brake other works running lights the elements in the bulb for tail lites are bad . so just replace bulbs. hope this helps.
Sep 13, 2011 | 2002 Volkswagen Jetta TDI
Break lights not working properly
hi
silly thing to sugest but would you have the brake/side light bulbs in the wrong way? if you look closley at the bulbs there is two pins either side on the round silver part. 1 pin sits higher than the other, make sure you fit the bulbs in the bulb holders to match the pins on the bulb sounds complicated but it realy is an easy mistake to make.
Jan 26, 2010 | 2004 Jeep Grand Cherokee
Rear brake light will not come on. put new bulb
If the blinker and reverse lights work on the bad side maybe a new socket.
Dec 03, 2009 | 1998 Toyota Avalon
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kodak Carousel 650h Slide Projector Instruction Manual On Dvd Logo
204 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
