Pace PR150BNC Syscode loader with blue screen software download on my tv and cable will not come back on what is wrong
It has "V1.43 Pace PR150BNM SysCode Loader" Pace. Across the top of blue screen, what's up?
Element Electronics blue screen no signal Questions ... - Fixya
www.fixya.com > Forum > Tags > blue screen no signal
Blue screen with ''component 2'' in a box shows. Then it goes black.There is also a humming coming from the tv. I have unplugged everything from the tv, and ...
element tv problem - YouTube
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
... is a vid im attaching to my email to custamer support to try and fix my bad tv. ... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW ...
Dish Network - My element TV is saying "no signal". ' Directly
Jan 09, 2016 | Element Televison & Video
Can't get past blue screen with proscan what's wrong how the hell do you turn it on
do you have anything plugged in to it? the blue screen just means its not getting a signal. cable tv, roku. try switching between your inputs tell you see something on screen. hdmi. cable. you might also have to auto program for cable tv
Jul 26, 2015 | Proscan Televison & Video
LT-46151 mitsubishi tv, Green light flashes, no picture, back light is on, screen is blue.
If you have any later digital camera or phone with a compatible connector and cable, try connecting this first.
The set may be looking at the wrong input for signal.
Using your remote, check the setup menu to ensure that your source (cable, receiver, etc.) hasn't been accidentally changed.
Often, a blue screen means 'no signal.'
Jun 04, 2015 | Mitsubishi Televison & Video
Screen stays blue and wont show the picture
TV may be on the wrong input and that will give you a blue screen. When you turn the TV on and the screen starts lighting up it should show on the screen what input the tv is on. If it is not on correct input change input with the TV remote or buttons on the tv. If it is on the correct input try a power cycle on the cable box, just unplug the cable box power cord for a few seconds and then plug it back in. If neither of these solve the problem describe how the cable box is connected to the tv.
Mar 16, 2014 | Mitsubishi WS-55513 55" Rear Projection...
No sound no picture. message: V1.24 Pace Vegas 614 Loader The ASTB needs to download a new software. This could take a few minutes, please be patient. Tuning to frequency LKC: Done ...
Are you using the cable/Sat box? That sounds like you have the problem with your Sat box or the cable box, not the TV problem. It is trying to update the firmware.
You should contact the hardware provider.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 11, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung Impression SGH-A877. It's frozen - Black screen
Hi! Most probable the software is broken, so you need to go to a specialized service and get it resofted.
Dec 12, 2009 | Samsung SGH-A877 Impression Cell Phone
Typed in my password incorrectly
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
then, download and install the latest Handheld Software for your model then open DM and run the application loader once the USB cable is connected to the device. Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=02A32AD2669E6FE298E607FE7CC0E1A0&dl=FF0BB7FFD725C749027B7137AC414877
Just fill out the form and the software download is free.
Sep 28, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cant understand how to get firmware to flash starview 4 box please help
You will need a null modem cable DB9F to DB9F.
Null Modem Cable
http://www.maplin.co.uk/Search.aspx?criteria=L71BT&DOY=2m6
If your pc does not have a serial port you will need a USB to serial port adapter to use in conjunction with the null modem cable.
USB Adapter
http://www.maplin.co.uk/Module.aspx?Modu...erial%20Adaptor
These two cable links are only for reference as they can be purchased alot cheaper on fleabay.
You will need to know if you have a clone or genuine
Count the vents on top
18x7 = Clone
25x7 = Genuine
13x7 = 1st Generation
Also looking from the front
Scart to the left = Clone
Scart to the right = Genuine
Also you can go here to see some pics
http://www.freewebs.com/dooby2oon
ST@RVIEW 1
You will need the GTromloader, (Starvi*w software Uploader), found in the Starvi*w software folder of the link.
You will need version CryptStar-v1.5-Core400only firmw@re for GENUINES found in "Starvi*w" firmw@re folder here.
You will need version CryptStar-v1.5-Core257 firmw@re for CLONES found in "Starvi*w" firmw@re folder here.
ST@RVIEW 2 - THE B0X
You will need the GTromloader , v4.03_051005, (Starvi*w Software Uploader), found in "THE B0X" software folder of the link.
You will need version thebox_h20081204_455eE_apifound in "THE B0X" firmw@re folder here.
ST@RVIEW 3 - THE B0X SUP3R
You will need version GTRom_Super_8.02e for THE SUPR B0X found in "THE B0X SUPR" firmw@re folder. (UFL = Unified Firmware Loader) here .
St@rview 4 - TheboxSuperUSB You will need version V1.07 for TheboxSuperUSB found in "THE B0X SUPR USB" firmw@re folder here.
Instructions SV4 Supr USB
To load the files just drag them on to a memory stick and then put the memory stick in the USB port at the back of the receiver.
Then press the menu button on the remote there you will see USB at the bottom of the screen.
Just highlight USB with the remote then you will see the (Box Super USB Bin file) appear on the screen.
Highlight "theboxsuperusb_v1.01_beta" with the remote and press the ok button then you will see the file start loading in to the Box.
Once that is complete, do that again but with the "TheBoxSuperUSB_BG_LOGO_080904" file.
Once that is done,
• Turn on the box, press menu and go to installation,
• Select correct provider i.e. NTL, C/W or TW
• Then automatic scan
• Once the channels are found, exit back to the blank screen
• Press menu then 1570,
• Go down to the bottom option and turn EMU to ON.
• Now exit 3 times and go to S*y Sports and let it update.
All firmw@re/loader can be found in the link at the end of my post marked EAMO'S LIBRARY.
Updating Firmw@re SV 1/2/3
Connect your box and PC with a Null modem cable and switch on the cable box and put it on STANDBY.
(The Starvi*w does not need to be connected to TV to update it with GTROM)
Open GTROM Loader software make sure that you set the correct COM PORT that matches the one that is being used
Make sure App file only is selected, then click b1n File & browse to the firmw@re where you downloaded it to on your PC.
Run the GTROM loader by pressing Download and you will see the % progress increase then Download completed message on your PC.
Wait until you see the DOWNLOAD COMPLETE p0p up on your PC before removing the NULL MODEM CABLE.
The Starvi*w will then reboot
Disconnect from PC and connect back up to the TV :)
Aug 27, 2009 | StarTech.com StarView SV211K 2-port KVM...
Tobshiba projection screen
Some have a switch on the back that switches the ceneter mode and will kill the sound, If you have a blue screen there may be a defect in the cable box or the tv may be on the wrong source, might try to change the channel to 3?
Jun 11, 2007 | Toshiba TP61G60 61" Rear Projection...
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
Electro Med Services...
