It wont shut off, after it's warm in the room
    Master:
  • 742 Answers
Most ac/heat units will continue to run the fan as long as the unit is on.
Posted on Nov 18, 2014
Testimonial: "The flame wont stop, the heater just keeps running, & theres no way of shutting the fan off its not stop"
  • Michael Carroll Nov 19, 2014
    You have a bad thermostat or control valve then
Does this model shut off automatically when the desired room temperature is reached or does it function on a low medium high type of thermostat that continuously runs? IR 3 0 p m d g - 1
if it is an inverter type air conditioner ( make not indicated) the unit runs continually but the compressor delivery is reduced thereby reducing the load on the motor
as the room warms up again the compressor starts to pump more gas to keep the room at the desired temp setting
older types shut the compressor down and restarted when the high temp was reached
Jan 19, 2018 | Heating & Cooling
My tv will play for an hour or so, then will shut down. If I wait about half hour, will start playing again, then the same thin
If this is a DLP television, it could be getting warm in the room it is in. Usually they will shut down like that when the thermostat detects a certain temperature to save the TV from overheating and damaging components.
If you have a cooler room in the house, see if it still happens.
Jul 16, 2008 | Philips Televison & Video
I have a Charmglow electric fireplace that does not heat nor does the blower work. The flame light does turn on and turns. Model # 6901050100 Cat # 409896 It worked then quit. tore it apart, it wo
Did your circuit breaker blow.in your electrical box. Check that first before anything else. Sometimes if you have anything else on the same circut as a heater the breaker will shut down.
Jan 05, 2015 | Heating & Cooling
Why does the unit not turn back on for hours even when the room is hot?
You may have a bad thermostat or the unit breaker shut your unit donw for protection overload
Aug 03, 2014 | Danby 5000 Btu Window Air Conditioner
My unit runs putting out warm air then begins putting out cold air alternating between warm and cold never shutting off
I think you you are setting as same as exact of your room temp. Please make it less setting and then check.
Dec 12, 2010 | Haier Heating & Cooling
Heater shuts itself totaly off as soon as the room is warm
Difficult to guess what the problem might be due to the amount of electronics the unit has that could cause inconsistent or illogical functioning.
I noted one product review that said "if the room is too large the auto shutdown will engage".
I suggest you revisit the instruction manual and specifications before deciding whether to call a service engineer....
Sep 24, 2017 | Bionaire BCH-4138 Ceramic Compact Heater
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
