Question about Cell Phones
My Nokia 521 Lumina displays a light ing Bolt and the settings symbol. Won't turn on, why?
    Sergeant:
  • 266 Answers
Press Power + Volume(down) keys until the phone vibrates (about 8-10 seconds). See if it switches ON. If not let the battery go flat. Then connect the charger. Leave it for about an hour and see if it has switched ON by itself. If not try resetting it again.
Posted on Nov 18, 2014
How can i get a free unlock code for my nokia lumina 521 i Mei #356706054811636 i had service with metro pcs but want to use my phone att
To get the free unlocking service i would recommend the site Unlock-Free.com where the providing codes are genuine.
http://www.unlock-free.com/
Nov 26, 2017 | Nokia Cell Phones
What does a battery with a lighting bolt on it mean
It is telling you to charge it or that it IS charging.
Jan 20, 2016 | Cell Phones
My Nokia lumina 521 got a saturatedecent in water 4 days ago & it does nothing ??
I suggest that you consider a new one as when electronics get saturated they generally fail completely
Sep 09, 2014 | Cell Phones
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
On GSM ariena it says the Nokia 5800 has a flash light how do I turn it on and off?
when you select camera of the main menu there is a symbol on the right hand sise of the screen which shows an A with a symbol next to it what reminds me of a bolt of lightening.. if you press that you are given a list of options for the flash. this is on network setting GSM, on a nokia 5800 xpressmusic. hope this helps.
Sep 12, 2010 | Nokia 5800 XpressMusic Smartphone
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
I own a 71 datsun pl 521 pickup. The IGN. warning light on the dash turns on and off as I drive. I installed a new fan belt and adjusted the tension to the service manul specs. No help. I installed a...
withthe ING light on it means one of three things battery is low or altaanator is not charging or battery posts and or cables dirty and loose You may have a malfunction in the points as well. Does it back fire or run rough?
Oct 07, 2009 | 2000 Datsun 510
1997 lumina how to do front wheel alignment
you set the camber by loosening the two bolts that bolt the strut to the steering knuckle move strut in or out check with camber gauge and tighten bolts when preferred setting is reached most cars are set around 0 degrees.Next you set the toe by turning the tie rods set toe on 0 while steering wheel is in the center.You need a alignment machine to do this correctly
Jul 24, 2009 | 1997 Chevrolet Lumina
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
